mpls over atm-ppp-llc
amms68958
Does cisco support mpls over atm-ppp-llc
per RFC 2354(PPP over AAL5).
Something like a scenario if Cisco acts as a PE and it gets frames with mpls over atm-ppp-llc from a connected CE ,is it supported in cisco , or it will drop the frames ?
Thanks in advance
Peter Paluch
There is a dedicated MPLS forum in the Service Provider section. You might want to post the MPLS-related questions there in the future. No offense intended, it's just the topic belongs more there :-)
Excuse me if I got your idea wrong but do you want to run MPLS on a PE-CE link that is provided by PPP over AAL5? Usually, the MPLS is not run on PE-CE links. Do you require having MPLS on them?
Best regards,
Peter
