04-22-2022 06:41 AM
Dear all,
I need to configure a Cisco C1113 (router B) to enable BGP Routing between two networks.
Router A is already configured by my provider and I need to configure my router B, but I would need to make sure that my configuration is correct...
Here is the connexion I established:
ASN 50624 ASN 50600 (vlan2)
______ ______ 10.1.0.10
10.0.0.0 | | 169.254.253.1 | | 10.1.0.11
---------| A |-----------------------| B |---------- 10.1.0.14
|______| 169.254.253.2 |______| 10.1.0.24
connexion between router A and B is done through a SFP FiberI would need to make sure that my 4 IPs from ASN 50600 are available over the network 10.0.0.0...
Here is the configuration I set:
for interfaces:
enable configure terminal interface GigabitEthernet0/1/0 switchport mode access switchport access vlan 2 interface vlan 2 ip address 10.1.0.10 255.255.255.0 description TS1 end configure terminal interface GigabitEthernet0/1/1 switchport mode access switchport access vlan 2 interface vlan 2 ip address 10.1.0.11 255.255.255.0 description TS 2 end configure terminal interface GigabitEthernet0/1/2 switchport mode access switchport access vlan 2 interface vlan 2 ip address 10.1.0.24 255.255.255.0 description H Preprod end configure terminal interface GigabitEthernet0/1/3 switchport mode access switchport access vlan 2 interface vlan 2 ip address 10.1.0.14 255.255.255.0 description H Prod end
and for BGP:
enable configure terminal ip route 10.1.0.0 255.255.255.0 null 0 interface GigabitEthernet0/0/0.2 encapsulation dot1q 2 ip address 169.254.253.2 255.255.255.0 end enable configure terminal router bgp 50600 redistribute connected redistribute static bgp router-id 169.254.253.2 bgp log-neighbor-changes neighbor 169.254.253.1 remote-as 50624 network 10.1.0.0 mask 255.255.255.0 address-family ipv4 unicast redistribute connected neighbor 169.254.253.1 default-originate neighbor 169.254.253.1 advertisement-interval 25 network 10.1.0.0 mask 255.255.255.0 neighbor 169.254.253.1 activate exit-address-family address-family ipv4 multicast redistribute connected neighbor 169.254.253.1 default-originate neighbor 169.254.253.1 advertisement-interval 25 network 10.1.0.0 mask 255.255.255.0 neighbor 169.254.253.1 activate exit-address-family neighbor 192.254.253.1 activate end
As I'm not familiar with BGP Protocol, if you can just help me to make sure that configuration is set correctly ? do I need to perform any additional configuration ?
Many thanks for your help !
Solved! Go to Solution.
04-22-2022 07:00 AM
Hello
Not sure you need to send a default route or advertise the null static towards your provider, apart from that the bgp configuration looks okay
04-22-2022 07:00 AM
Hello
04-22-2022 07:12 AM
thanks paul for your confirmation, I'll launch this config in the coming days as I need to be onsite to do it...
