Two subnets with 1 router and switch?
jasonfaas
I may very well be overlooking something as I am still very new to this but one of my practices for an exam coming up is having to be able to use 1 router(4221 it says), 1 switch (2960), and 2 pcs, and I have to create two subnets.  It says in the table that I have to use G0/0/0 AND g0/0/1 on the router, but if there is only one switch, how does that work?
jasonfaas
Thank you for the replies.  After a second look, I checked out the topology at the top of the project and it showed the router being directly connected to one of the PC's on one subnet (G0/0/1) and a switch and PC on the other subnet (G0/0/0) so it finally made sense.  I eventually did it all and everything worked, except I got to the point where I could ping everything EXCEPT the VLAN 1 interface on the switch and only with IPv6.  I could ping it with IPv4.  I made sure I had IPv6 unicast-routing enabled on the router and had "sdm prefer dual-ipv4-and-ipv6 default" and reloaded the switch and still couldnt get it.  The odd thing was I could ping right through it to the PC attached to the switch.  Any ideas?  I eventually went and made static routes on the switch and router and I think it worked, however I didnt think at the time that this was necessary since it would ping through the switch to the PC.
6 Replies 6
balaji.bandi
In most cases 1 Interface towards the internet, 1 connected to Lan. with that assumption below example help you :
Router on a stick is the config :
https://networklessons.com/cisco/ccna-routing-switching-icnd1-100-105/how-to-configure-router-on-a-stick
BB
Hello
@jasonfaas wrote:
I may very well be overlooking something as I am still very new to this but one of my practices for an exam coming up is having create two subnets.  It says in the table that I have to use G0/0/0 AND g0/0/1 on the router,
 how does that work?
You would use say gig0/0 for the WAN ( internet) connection and Gig0/1 for the two subnets, so making the router itself perform the inter-vlan routing (between the subnets) , I would also say you require Network Translation but as the question doesnt mention providing internet connectivity for the subnets we can leave this out.
Example router on a stick with two subnets (lets call them vlan 10 & 11)  :
Router
int gig0/0
description WAN
ip address x.x.x.x y.y.y.y.
no shut
interface gig0/1
description LAN
no shut
interface gig0/1.10
description Vlan10
encapsulation dot1q 10
ip address 192.168.10.1 255.255.255.0
interface gig0/1.11
description Vlan11
encapsulation dot1q 11
ip address 192.168.11.1 255.255.255.0
ip dhcp pool LAN
network 192.168.10.0/24
default-router 192.168.10.1
network 192.168.11.0/24 secondary
override default-router 192.168.11.1
lease 0 8
Switch
vlan 10,11
exit
interface gig0/1
description trunk to router
switchport mode trunk
no shut
interface gig0/2
description host in vlan 10
switchport host
switchport access vlan 10
no shut
interface gig0/3
description host in vlan 11
switchport host
switchport access vlan 11
no shut
Kind Regards
Paul
Jon Marshall
If that is all the question asks then there is no mention of the internet so no need for routing on a stick.
Just create two vlans on the switch with a subnet each and then put g0/0/0 and one of the PCs in the first vlan and gi0/0/1 and the second PC in the other vlan.
Jon
this sounds like a Packet Tracer project. I think what they want you to do is create two Vlans on the switch. The entire thing would look like the project in the attachment.
Hello
Creating two vlans on a 2960 -well yes but with limited L3 functionality as its really just access-layer switch.
Kind Regards
Paul
jasonfaas
