Configuring BGP/RIP between two VRFs
Hello Everyone, i'm having a trouble configuring
BGP and RIP
between two VRFs .The idea was to configure as many protocols and get hands-on experince using only one router.
This is my configuration:
version 15.0
hostname myrouter
boot-start-marker
boot-end-marker
enable secret xxx
enable password xxx
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip vrf blue
rd 65000:1
bgp next-hop Loopback1
ip vrf red
rd 65000:2
bgp next-hop Loopback2
license udi pid CISCO1921/K9 sn xxx
interface Loopback1
ip vrf forwarding red
ip address 10.0.0.1 255.255.255.255
ip rip send version 2
ip rip receive version 2
interface Loopback2
ip vrf forwarding blue
ip address 10.0.0.2 255.255.255.255
interface Loopback10
ip address 128.0.0.1 255.255.0.0
interface Loopback20
ip address 129.0.0.2 255.255.0.0
interface GigabitEthernet0/0
bandwidth 100
ip address 192.168.1.12 255.255.255.0
ip ospf network point-to-point
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description unused available port
ip address 192.168.1.13 255.255.255.0
duplex auto
speed auto
no mop enabled
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
router ospf 2 vrf blue
router-id 10.0.0.2
log-adjacency-changes
redistribute static subnets
network 192.168.1.0 0.0.0.255 area 0
router ospf 1 vrf red
router-id 10.0.0.1
router rip
version 2
address-family ipv4 vrf red
network 10.0.0.0
no auto-summary
exit-address-family
address-family ipv4 vrf blue
network 10.0.0.0
no auto-summary
exit-address-family
router bgp 40000
bgp router-id 10.0.0.1
bgp log-neighbor-changes
neighbor 10.0.0.2 remote-as 45000
address-family ipv4
no synchronization
network 10.0.0.0
network 10.0.0.0 mask 255.255.255.255
network 192.168.1.0
neighbor 10.0.0.2 activate
no auto-summary
exit-address-family
no synchronization
redistribute connected
redistribute static
neighbor 10.0.0.1 remote-as 40000
neighbor 10.0.0.1 activate
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route vrf blue 10.2.0.0 255.255.255.0 Null0
snmp-server community public RO
control-plane
line con 0
exec-timeout 0 0
password xxx
line aux 0
password xxx
login
modem InOut
transport input all
speed 115200
flowcontrol hardware
line vty 0 4
password xxx
login
transport input all
line vty 5 15
password xxx
login
scheduler allocate 20000 1000
end
I was trying to test and learn as much as i can using this one router.
the two interfaces are directly connected with 4 pair RJ-45 Cable.
Both
RIP and BGP
doesn't even show up .
Any help will be much appreciated.
https://networkdirection.net/articles/routingandswitching/mp-bgp/leakingrouteswithmp-bgp/
this link for config
BGP route leaking
must important part
route-target import/export
BGP route leaking
must important part
"If we are using
MP-BGP
, this solution should work. However, if we are configuring regular
BGP
, there are some changes that need to be made, right?
I'm also having trouble understanding why
RIP
isn't functioning properly. Can anyone please provide more details or share any specific error messages they encountered? It would be helpful to diagnose the issue and provide a more accurate solution. Thank you!"
Hello @Cisco Enthusiast ,
RIP
You are attempting to build
RIP
neighborships on loopback interfaces, but this is not possibile . A loopback interface is a logical interface isolated from outside world if using an appropriate
debug
command you should see a loopback receiving back only its own
RIP
advertisements sourced by itself.
In order to make a
RIP
neighborship you should run
RIP
also on the LAN interfaces that are interconnected with a LAN cable
gi0/0 and gi0/1
by adding a
network
command for subnet 192.168.1.0 under the two address families in
 RIP router
process.
For
BGP
you are attempting to use
iBGP
within a vrf and also this is something that is uncommon, but you have a single router that cannot be in two different
BGP
ASes at the same time. There are some tricks like  neighbor ... local-as that could be used but I would suggest you to try to fix the
RIP
Also OSPF could be used to build the inter VRF communication.
Hope to help
Giuseppe
Harold Ritter
Hi @Cisco Enthusiast ,
A few things you need to change for the
BGP
session to come up.
1. Advertise the loopback addresses in ospf for
vrf
red and blue.
network 10.0.0.2 0.0.0.0
area 0!
network 10.0.0.1 0.0.0.0 area 0
2. The following section of the
BGP
configuration should be configured for
vrf red
, not for global, as the session is established between
vrf red
and
vrf blue
(10.0.0.1 to 10.0.0.2).
address-family ipv4
no synchronization
network 10.0.0.0
network 192.168.1.0
no auto-summary
exit-address-family
it should be
no synchronization
network 10.0.0.0
network 192.168.1.0
no auto-summary
exit-address-family
3. Configure a different
BGP router id for vrf red and blue
. Otherwise the default will be used and the session will not come up, as the router id will be the same for both neighbors.
address-family ipv4
vrf red
address-family ipv4
vrf blue
bgp router-id 10.0.0.2
