Configuring Cluster-ID in RR
arun kumar
I ve two Route Reflectors for MP-BGP session with multiple clients. All clients are configured under a peer-group. The setup is up and working fine. Now i want to configure cluster-id in the RR's (though its not required in our current setup with one cluster we would require in the future and make it as a standard setup). I heard to configure Cluster-ID in a RR requires BGP peer-group configuration need to be removed prior to that. Are there any prerequisites to be done before configuring Cluster-ID in Route Reflectors?
Thanks in advance..
dongdongliu
hi all
I`m not sure but I think maybe "cle ip bgp* or cle ip bgp peer-group-name" will re-establish connection between bgp peer and do not need remove prior configuration about peer-group after add a cluster-ID.
I`d like to learn this with Arun together.
thanks
dongdong
I got the basic prerequisite for configuring Cluster ID in a RR which is running with existing Clients.
"Configuring Cluster ID in RR requires no clients be configured on the RR. If any clients are configured, need to unconfigure it and configure Cluster ID then re-configure the clients".
Anyhow i would like to hear from Pro's are there any more changes to be done for configuring Cluster ID.
bvsnarayana03
Level 5
Level 5
hi Arun,
As far as I know, cluster-id has to be the same for both RR's to be redundant. Every client should peer with each RR, and
RR's should have the same cluster-id and peer with each other via
iBGP, they should not be clients of each other.
I have a sample config of both peer-group & cluster-id configured. So there seems to be no pre-requisite.
router bgp 100
no synchronization
bgp cluster-id 100
neighbor reflectors peer-group
neighbor reflectors remote-as 1
neighbor reflectors update-source Loopback0
neighbor clients peer-group
neighbor clients remote-as 1
neighbor clients update-source Loopback0
neighbor clients route-reflector-client
neighbor 2.2.2.2 peer-group reflectors
neighbor 3.3.3.3 peer-group clients
neighbor 4.4.4.4 peer-group clients
neighbor 5.5.5.5 peer-group clients
no auto-summary
