I can't access web server with public address from internal lan behind ASA
san_dec21
thanks in advance
One of my customer have topology like below
Lan---ASA----Router--------internet
Behind ASA in lan their is one web server which is natted with public ip on asa.Internet users can access the web server with public dns name.But when internal client try to access the web server with public dns name,it is not working.we had tried dns doctoring ,but no positive result.we also tried by configuring public dns on asa outside interface,but fail.
Can some help me to sort out this problem
shivlu jain
Level 5
Level 5
are you using nat 0 or not
regards
shivlu
Goutam Sanyal
Level 4
Level 4
Go for DNS Doctoring with Static NAT:
#static (lan_zone,out_side) out_side_ip lan_zone_ip netmask 255.255.255.255
#static (lan_zone,lan_zone) out_side_ip lan_zone_ip netmask 255.255.255.255
Note: Asumeing its in LAN_Zone,no ACL is required.
Goutam
pls rate if it helps u!!!
Goutam Sanyal
Level 4
Level 4
Problem solved?
Goutam
