05-01-2021 02:09 AM
Hi All,
I have started a quick setup via the Cisco CP Express web UI and have run into an issue.
When selecting Cellular0/0/0 as the primary WAN, and I finalise the setup, I get an error: "Invalid input detected. Command: dialer string".
The CLI preview is below, which I tried to run execute in a terminal, but no luck.
Any assistance would be great!
William
Cisco Configuration Professional Express Quick Setup Wizard Basic Primary WAN Backup WAN LAN Confirm & Apply Invalid input detected. Command: dialer string Summary Basic Router Name:VT-STKN-RTR-0001 Domain Name:vergetel TimeZone:(GMT+10:00) Canberra, Melbourne, Sydney DNS Server:Automatic Primary WAN WAN Interface: Cellular 0/0/0 Ipv4: Automatic Ipv6: Not configured NAT: Enabled Persistance: Enabled Backup WAN Not Configured LAN LAN Interface: Vlan 1 with switch ports GigabitEthernet LAN Network: 10.10.10.0 Subnet Mask: 255.255.255.128 Security Not Configured CLI Preview Cancel CLI Preview close hostname VT-STKN-RTR-0001 ip domain name vergetel clock timezone GMT 10 ip dhcp pool ccp-pool dns-server 10.10.10.1 exit ip dns server ip dns view default default dns forwarder default dns forwarding default domain lookup default domain name-server interface GigabitEthernet0/1 ip nat inside exit object-group network local_lan_subnets 10.10.10.0 255.255.255.128 ip access-list extended nat-list permit ip object-group local_lan_subnets any deny ip any any default interface Cellular 0/0/0 no chat-script lte chat-script lte "" "AT!CALL1" TIMEOUT 20 "OK" interface Dialer1 description PrimaryWANDesc___Cellular0/0/0 encapsulation slip ip nat outside ip address negotiated dialer pool 1 dialer-group 1 dialer persistent dialer string dialer idle-timeout 0 no shut exit interface Cellular 0/0/0 description PrimaryWANDesc_ no shut load-interval 30 dialer in-band no peer default ip address dialer pool-member 1 async mode interactive ip nat outside exit line 0/0/0 script dialer modem InOut no exec transport input all transport output all ip forward-protocol nd dialer-list 1 protocol ip permit access-list 23 permit 10.10.10.0 0.0.0.127 ip route 0.0.0.0 0.0.0.0 Dialer1 ip nat inside source list nat-list interface Dialer1 overload
05-01-2021 02:27 AM
- Check if this thread can provide hints :
M.
05-01-2021 05:16 PM
Thanks, Marce, this was the thread I referred to and still couldn't get it working.
05-01-2021 02:40 AM
the dialer string command requires a parameter that is the number to be called
dialer string <string>
in your configuration it appears with no parameter.
see the following configuration guide for LTE 4G
in addiiton the script dialer appears not defined in your configuration.
Follow the guide provided above as before being able to use the Cellular interface there are some steps to be done like configuring the SIM for data calls and so on.
if you provide a show inventory we can see what exact model of hardware is in your router.
Hope to help
Giuseppe
05-01-2021 02:49 AM
Hello
Try adding :
line 0/0/0
script dialer lte
05-01-2021 05:44 PM
Hi Paul,
I just tried the following in the Configure CLI section of CP Express and got an error: "invalid input detected". I added the two config lines to their indicated locations in the command and still nothing - see screenshot.
I copied and paste the below directly into the CLI, so could there be a formatting issue?
hostname VT-STKN-RTR-0001 ! ip domain name vergetel ! clock timezone GMT 10 ! ip dhcp pool ccp-pool dns-server 10.10.10.1 exit ip dns server ! ip dns view default default dns forwarder default dns forwarding default domain lookup default domain name-server ! interface GigabitEthernet0/1 ip nat inside exit ! object-group network local_lan_subnets 10.10.10.0 255.255.255.128 ! ip access-list extended nat-list permit ip object-group local_lan_subnets any deny ip any any ! default interface Cellular 0/0/0 ! no chat-script lte ! chat-script lte "" "AT!CALL1" TIMEOUT 20 "OK" ! interface Dialer1 description PrimaryWANDesc___Cellular0/0/0 encapsulation slip ip nat outside ip address negotiated dialer pool 1 dialer-group 1 dialer persistent dialer string dialer idle-timeout 0 no shut exit ! interface Cellular 0/0/0 description PrimaryWANDesc_ no shut load-interval 30 dialer in-band no peer default ip address ip address negotiated dialer pool-member 1 async mode interactive ip nat outside exit ! line 0/0/0 script dialer lte modem InOut no exec transport input all transport output all ! ip forward-protocol nd dialer-list 1 protocol ip permit ! access-list 23 permit 10.10.10.0 0.0.0.127 ip route 0.0.0.0 0.0.0.0 Dialer1 ip nat inside source list nat-list interface Dialer1 overload
05-01-2021 07:48 PM - edited 05-01-2021 07:48 PM
I just got that command to work after adding the dialer string to a third section:
interface Dialer1
dialer string lte
Now when I check back in the interfaces tab, cellular 0/0/0 is showing 'down'. I've restarted the unit and no change.
I've also configured GigabitEthernet0/0 to work with IPv4 DHCP, so I'll assume no further programming is required for that interface to now work as the non-management LAN interface.
Thanks again and await your reply.
