Access List...OSPF
jstickland
Hello, without an access list, OSPF works fine. I then tried the following
access-list 100 permit ospf 172.16.16.0 0.0.0.7 host 172.16.16.1
int e0
ip access-group 100 in
With the access list on the interface, OSPF does not work. With it off, OSPF works great.
Am I supposed to add additional rules to the acl? 224.0.0.5, 224.0.0.6 destination addresses coming in on the interface maybe?
9 Replies 9
jstickland
Replying to my message is a bit silly, but as i look at my syslog (which is still not showing unicast), i see
DENY: 172.16.16.2 -> 224.0.0.5
Looks like i need an entry for "all ospf routers"
what is the mission objective? You wish to deny OSPF neighbors to form adjacency or what? Please be more specific with your question.
Yes you need to consider routing protocols in any inbound ACLs, but not with outbound ACLs as outbound ACLs don't affect locally generated traffic.
HTH,
Mohammed Mahmoud.
James,
Your access list would work if it was a unicast OSPF packet to host 172.16.16.1 but it's a multicast packet.
You don't even need to specify the source or destination in the access list as multicast packets have a TTL of 1 and thus only OSPF multicast packets local to the subnet will ever arrive in the router.
Reconfigure the access list as follows and try.
access-list 100 permit ospf any any
(or)
access-list 100 permit ospf 172.16.16.0 0.0.0.7 any
Sundar
Hi Sundar,
I totally agree with you about the TTL issue, but i guess that he might be in a situation that he needs to constrain even the local subnet routers that can have OSPF neighborship with the local router.
Rack1R1#sh ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
155.1.146.4 1 FULL/DR 00:00:30 155.1.146.4 FastEthernet0/0
Rack1R1#sh access-lists 101
Extended IP access list 101
10 permit ospf host 155.1.146.4 host 224.0.0.6 log
20 permit ospf host 155.1.146.4 host 224.0.0.5 log (3 matches)
Rack1R1#
HTH,
Mohammed Mahmoud.
Mohammed,
In a broadcast multiaccess segment it can create problems if only select routers become OSPF neighbors. I don't have access to a lab at this time to test and post the results. You might want to try this is your lab and check the outcome.
Sundar
Hi Sundar,
I've tried it in the lab and it seemed fine, can you elaborate more on the problems that should arise, i am really interested.
BR,
Mohammed Mahmoud.
Mohammed,
Can you try the following example and check whether R3 puts the route (1.1.1.1/32) in it's routing table. I would expect it shouldn't because the LSA on R3 should show the next hop to get to 1.1.1.1/32 as 172.30.1.11 (R3) which R3 would consider as not reachable because of the ACL. That's a problem that can stem from selective filtering of OSPF neighbors in a multiaccess segment.
R1:
int lo0
ip add 1.1.1.1/32
int e0
ip add 172.30.1.11/24
router bgp 1
neig 172.30.1.12 remote-as 2
net 1.1.1.1 mask 255.255.255.255
R2:
int e0
ip add 172.30.1.12/24
router bgp 2
nei 172.30.1.11 remote-as 1
router ospf 1
net 172.30.1.12 0.0.0.0 area 0
redistribute bgp 2 subnets
R3:
int e0
ip add 172.30.1.13/24
ip access-group ospf in
router ospf 1
net 172.30.1.13 0.0.0.0 area 0
ip access-group ext OSPF in
deny ospf host 172.30.1.11 any
permit ip any any
Let me know what you find.
Sundar
BRAVO!!
