Configuring my C891F
Hakim RS
Hi Everyone,
I have a Cisco 891F router, i need to configure two LAN s segements on this router and connect it with two ISP's router. One ISP will be placed on the Gi8 interface and the other with Fa0
My question is , how can i configure the router so the first LAN will be served from the first ISP. And the second LAN with th other
2 Accepted Solutions
a.alekseev
Level 7
Level 7
someting like this
ip vrf ISP1
 rd 1:1
ip vrf ISP2
 rd 2:2
ip dhcp pool vlan1-pool
import all
vrf ISP1
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 8.8.8.8
ip dhcp pool vlan2-pool
import all
vrf ISP2
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
interface GigabitEthernet0
no ip address
spanning-tree portfast
switchport access vlan 1
interface GigabitEthernet1
no ip address
switchport access vlan 2
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
description ## ISP1 ##
ip vrf forwarding ISP1
ip nat outside
ip address x.x.x.x x.x.x.x
interface GigabitEthernet9
description ## ISP2 ##
ip vrf forwarding ISP2
ip address y.y.y.y y.y.y.y
ip nat outside
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1380
interface Vlan2
ip nat inside
route-map NAT-ISP1 permit 10
match interface GigabitEthernet8
route-map NAT-ISP2 permit 10
match interface GigabitEthernet9
ip nat inside source route-map NAT-ISP1 interface GigabitEthernet8 vrf ISP1 overload
ip nat inside source route-map NAT-ISP2 interface GigabitEthernet9 vrf ISP2 overload
ip route vrf ISP1 0.0.0.0 0.0.0.0 x.x.x.x name ISP1
ip route vrf ISP2 0.0.0.0 0.0.0.0 y.y.y.y name ISP2
no ip nat inside source route-map NAT-proximus interface FastEthernet0 vrf proximus overload
no ip nat inside source route-map NAT-voo interface GigabitEthernet8 vrf voo overload
ip nat inside source route-map NAT-proximus interface FastEthernet0 vrf lan-etudiants overload
ip nat inside source route-map NAT-voo interface GigabitEthernet8 vrf lan-employes overload
and
on PC
ping 8.8.8.8
on router
sh ip nat tr
30 Replies 30
a.alekseev
Level 7
Level 7
someting like this
ip vrf ISP1
 rd 1:1
ip vrf ISP2
 rd 2:2
import all
vrf ISP1
dns-server 8.8.8.8
import all
vrf ISP2
dns-server 8.8.8.8
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip nat outside
ip nat outside
interface Vlan1
ip nat inside
interface Vlan2
ip nat inside
Thank you a.alekseev for sharing this
I ll try to configure my router the same way and tell u the results
ip vrf lan-employes
rd 65000:99
route-target export 65000:99
route-target import 65000:1
ip vrf lan-etudiants
rd 65000:98
route-target export 65000:98
route-target import 65000:2
ip vrf proximus
rd 65000:2
route-target export 65000:2
route-target import 65000:98
ip vrf voo
rd 65000:1
route-target export 65000:1
route-target import 65000:99
for get this working you must use BGP
like this ?
router bgp 65000
bgp log-neighbor-changes
address-family ipv4 vrf lan-employes
redistribute connected
exit-address-family
address-family ipv4 vrf lan-etudiants
exit-address-family
address-family ipv4 vrf proximus
default-information originate
exit-address-family
address-family ipv4 vrf voo
exit-address-family
yes.
description **voo**
ip vrf forwarding voo
no ip address
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
You haven't ip address configured...
yeah yeah i corrected it, but still no result
look at routing table for vrfs
I must also redistribute defaults routes.
How can i doo that please?
route-map STATIC2BGP permit 10
 match tag 999
ip route vrf voo 0.0.0.0 0.0.0.0 192.168.0.1 name voo tag 999
ip route vrf proximus 0.0.0.0 0.0.0.0 10.0.0.1 name proximus tag 999
router bgp 65000
exit-address-family
exit-address-family
redistribute static route-map STATIC2BGP
exit-address-family
exit-address-family
stiill i don t any result :s i can teven ping 8.8.8.8 from my router or even ping the ISP router 192.168.0.1
show your routing tables
RouterC891F#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is not set
RouterC891F#sh ip route vrf voo
Routing Table: voo
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.0.1
192.168.0.0/24 is variably subnetted, 3 subnets, 2 masks
C 192.168.0.0/24 is directly connected, GigabitEthernet8
S 192.168.0.1/32 [254/0] via 192.168.0.1, GigabitEthernet8
L 192.168.0.4/32 is directly connected, GigabitEthernet8
RouterC891F#sh ip route vrf proximus
Routing Table: proximus
192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
B 192.168.20.0/24
is directly connected (lan-etudiants), 00:30:23, Vlan200
L 192.168.20.1/32 is directly connected, Vlan200
RouterC891F#sh ip route vrf lan-etudiants
Routing Table: lan-etudiants
C 192.168.20.0/24 is directly connected, Vlan200
RouterC891F#sh ip route vrf lan-employes
Routing Table: lan-employes
B* 0.0.0.0/0 [20/0] via 192.168.0.1 (voo), 00:06:22
192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
B 192.168.0.0/24
is directly connected (voo), 00:30:59, GigabitEthernet8
where is no route for 10.0.0.1 in vrf proximus
so default route is not working.
how did you checked that ping 8.8.8.8 is not working?
well now i putted an isp on gi8 (192.168..0.1) the gi8 got an ip ( 192.168.0.4)
on priviliged mod i tried to ping the 192.168.0.1 and 8.8.8.8 but doesn t work
