Configuring my C891F
Hakim RS
Hi Everyone,
I have a Cisco 891F router, i need to configure two LAN s segements on this router and connect it with two ISP's router. One ISP will be placed on the Gi8 interface and the other with Fa0
My question is , how can i configure the router so the first LAN will be served from the first ISP. And the second LAN with th other
30 Replies 30
i should add a route in vrf proximus ? or in the normal routes for 10.0.0.1
should be
#ping vrf voo 8.8.8.8 source GigabitEthernet8
#ping vrf proximus 8.8.8.8 source f0
ah yeah that worked, what about the ip route for proximus u told me i forgot
interface FastEthernet0
description **proximus**
ip vrf forwarding proximus
ip address 10.0.0.2 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
ip route vrf proximus 0.0.0.0 0.0.0.0 10.0.0.1 name proximus
RouterC891F#sh ip route vrf proximus
Routing Table: proximus
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is not set
192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
B 192.168.20.0/24
is directly connected (lan-etudiants), 00:30:23, Vlan200
L 192.168.20.1/32 is directly connected, Vlan200
Probably your FastEthernet0 is down. Check it.
Still when i connect PC's to the LAN they don t get any addrees ip
here s what show ip dhcp binding  shows :
RouterC891F#sh ip dhcp binding
Bindings from all pools not associated with VRF:
IP address Client-ID/ Lease expiration Type
Hardware address/
User name
Bindings from VRF pool proximus:
Hardware address/
User name
Bindings from VRF pool voo:
Hardware address/
User name
I m a bit lost now
You are using wrong vrfs in dhcp pools....
Now it s gets more crazy, the pcs received ip address but doesn t respect the excluded addresses rules.
exemple :  i configured an addresses-excluded rule to jump of the address 192.168.8.1- 192.168.8.10 but when i attached a pc . the routeur assigned 192.168.8.2 to the machine
and still no internet
R1(config)#ip dhcp excluded-address ?
  A.B.C.D  Low IP address
  vrf      VRF name for excluded address range
R1(config)#ip dhcp excluded-address vrf lan-employes ?
Thank you, but still don t habve internet. is it  the routing ?
when i tried to ping different destinations here s what i got:
RouterC891F#ping vrf voo 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/16/16 ms
RouterC891F#ping vrf voo 192.168.8.2
Sending 5, 100-byte ICMP Echos to 192.168.8.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
RouterC891F#ping vrf lan-employes 192.168.8.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
RouterC891F#
show the outputs:
sh run
sh ip dhcp binding
on the PC run:
ipconfig /all
ping 8.8.8.8 -t
on the router:
sh ip nat tr
sh ip route vrf voo
sh ip route vrf lan-employes
except that i don t have access on the pc, i m configuring the router from distance and i m accessing it trough serial connection via another pc that i m remoting using teamviewer.
but they told me there s no internet in it , even if the dhcp, dns and gateway are all correct
show run :
Hardware address/
User name
Bindings from VRF pool lan-employes:
Hardware address/
User name
192.168.8.2 0100.23ae.2357.ac May 10 2017 01:28 PM Automatic
Bindings from VRF pool lan-etudiants:
Hardware address/
User name
192.168.20.2 0100.23ae.2357.ac May 10 2017 01:18 PM Automatic
sh ip nat tr   doesn t show anything
RouterC891F#sh ip route vrf voo
Routing Table: voo
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 192.168.0.1
192.168.0.0/24 is variably subnetted, 3 subnets, 2 masks
C 192.168.0.0/24 is directly connected, GigabitEthernet8
S 192.168.0.1/32 [254/0] via 192.168.0.1, GigabitEthernet8
L 192.168.0.4/32 is directly connected, GigabitEthernet8
192.168.8.0/24 is variably subnetted, 2 subnets, 2 masks
B 192.168.8.0/24
is directly connected (lan-employes), 02:43:40, Vlan100
L 192.168.8.1/32 is directly connected, Vlan100
RouterC891F#sh ip route vrf lan-employes
Routing Table: lan-employes
B* 0.0.0.0/0 [20/0] via 192.168.0.1 (voo), 00:41:32
192.168.0.0/24 is variably subnetted, 2 subnets, 2 masks
B 192.168.0.0/24
is directly connected (voo), 23:58:32, GigabitEthernet8
C 192.168.8.0/24 is directly connected, Vlan100
no ip nat inside source route-map NAT-proximus interface FastEthernet0 vrf proximus overload
no ip nat inside source route-map NAT-voo interface GigabitEthernet8 vrf voo overload
ip nat inside source route-map NAT-proximus interface FastEthernet0 vrf lan-etudiants overload
ip nat inside source route-map NAT-voo interface GigabitEthernet8 vrf lan-employes overload
and
on PC
ping 8.8.8.8
on router
sh ip nat tr
thank you very much for everything u were very helpful.
It worked , i was mistaking in this
and here s what traceroute command shows:
RouterC891F#traceroute vrf lan-employes 192.168.8.2 source vlan100
Tracing the route to 192.168.8.2
VRF info: (vrf in name/id, vrf out name/id)
1 * * *
2 * * *
3* * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15* * *
16 * * *
17 * * *
18 * * *
