Configuring my C891F
Hakim RS
Hi Everyone,
I have a Cisco 891F router, i need to configure two LAN s segements on this router and connect it with two ISP's router. One ISP will be placed on the Gi8 interface and the other with Fa0
My question is , how can i configure the router so the first LAN will be served from the first ISP. And the second LAN with th other
30 Replies 30
well i changed the config, and now even the dhcp doesn t work, i putted pc's on the lan's and they don t receive ip addresses
here it is what sh running -config shows:
hostname RouterC891F
boot-start-marker
boot-end-marker
enable secret
enable password
no aaa new-model
ip vrf lan-employes
rd 65000:99
route-target export 65000:99
route-target import 65000:1
ip vrf lan-etudiants
rd 65000:98
route-target export 65000:98
route-target import 65000:2
ip vrf proximus
rd 65000:2
route-target export 65000:2
route-target import 65000:98
ip vrf voo
rd 65000:1
route-target export 65000:1
route-target import 65000:99
ip dhcp relay information option
ip dhcp excluded-address 192.168.8.1 192.168.8.29
ip dhcp excluded-address 192.168.8.201 192.168.8.254
ip dhcp excluded-address 192.168.20.1 192.168.20.9
ip dhcp excluded-address 192.168.20.251 192.168.20.254
ip dhcp excluded-address 192.168.1.10 192.168.1.254
ip dhcp excluded-address 192.168.8.1 192.168.8.10
ip dhcp excluded-address 192.168.20.1 192.168.20.10
ip dhcp excluded-address 192.168.20.250 192.168.20.254
ip dhcp excluded-address 192.168.8.250 192.168.8.254
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp pool vlan100
import all
vrf voo
network 192.168.8.0 255.255.255.0
dns-server 195.238.2.21 195.238.2.22
default-router 192.168.8.1
ip dhcp pool vlan200
import all
vrf proximus
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip dhcp pool proximus
network 192.168.1.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.1.1
ip dhcp class Employes
option 60 hex 010203
ip dhcp class Etudiants
ip dhcp class proximus
ip name-server 195.238.2.21
ip name-server 195.238.2.22
ip name-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid C891F-K9 sn FCZ205390HP
ip ssh version 1
ip ssh pubkey-chain
username
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
isdn point-to-point-setup
interface FastEthernet0
description **proximus**
ip vrf forwarding proximus
ip address 10.0.0.2 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
interface GigabitEthernet0
no ip address
duplex full
speed 100
interface GigabitEthernet1
switchport access vlan 100
no ip address
interface GigabitEthernet2
ip dhcp relay information option-insert
ip dhcp relay information check-reply
ip dhcp relay information policy-action replace
no ip address
duplex full
speed 100
interface GigabitEthernet3
switchport access vlan 200
no ip address
duplex full
speed 100
interface GigabitEthernet4
no ip address
shutdown
interface GigabitEthernet5
no ip address
shutdown
interface GigabitEthernet6
no ip address
shutdown
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
description **voo**
ip vrf forwarding voo
no ip address
ip nat outside
duplex auto
speed auto
interface Vlan1
ip address 192.168.10.1 255.255.255.0
interface Vlan100
description **Employes**
ip vrf forwarding lan-employes
ip address 192.168.8.1 255.255.255.0
ip helper-address global 192.168.8.1
ip nat inside
interface Vlan200
ip vrf forwarding lan-etudiants
ip address 192.168.20.1 255.255.255.0
ip helper-address global 192.168.20.1
ip nat inside
interface Vlan2000
no ip address
interface Async3
no ip address
encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map NAT-proximus interface FastEthernet0 vrf proximus overload
ip nat inside source route-map NAT-voo interface GigabitEthernet8 vrf voo overload
ip route 10.0.0.0 255.255.255.0 10.0.0.1
ip route vrf voo 0.0.0.0 0.0.0.0 192.168.0.1 name voo
ip route vrf proximus 0.0.0.0 0.0.0.0 10.0.0.1 name proximus
dialer-list 1 protocol ip permit
route-map NAT-voo permit 10
match interface GigabitEthernet8
route-map NAT-proximus permit 10
match interface FastEthernet0
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
flowcontrol hardware
line vty 0 4
password
login
transport input ssh
scheduler allocate 20000 1000
end
and here s what sh ip dhcp pool shows
Pool vlan100 :
Utilization mark (high/low) : 100 / 0
Subnet size (first/next) : 0 / 0
VRF name : voo
Total addresses : 254
Leased addresses : 0
Pending event : none
1 subnet is currently in the pool :
Current index IP address range Leased addresses
192.168.8.1 192.168.8.1 - 192.168.8.254 0
Pool vlan200 :
VRF name : proximus
192.168.20.1 192.168.20.1 - 192.168.20.254 0
Please help me checking this, if i missed something or i did smth wrong
