Re-numbering 3850 switch stack
andymorph
I've got 2 x 3850 switchs in a stack
Switch1 Active - PRI - 15
Switch2 Standby - PRI - 14
I want to change the switch number so that switch 2 is switch 1 and vice versa - I then want to change the priority of the switch as well.  I know the commands I need to use but im just wondering if im going to get any issues with regard port configs  The 48 ports on switch are different configs to the 48 ports on switch 2.  Will this config swap over as well ? or am I going to need to do a copy and paste on the config of the ports as well.
Any ideas well received :)
Leo Laohoo
switch 2 renum 1
Thanks for the reply - but my concern is :
The 48 ports on switch 1 are different configs to the 48 ports on switch 2.  Will this config swap over as well ? or am I going to need to do a copy and paste on the config of the ports as well.
Yes.  Gi 2/0/35, for example, will become Gi 1/0/35.
