Configuring NAT Failover to 4G LTE Verizon Card
tony.bany
I am using a Cisco 1921 with a Verizon 4G LTE card installed.  The primary connection is a Cable Modem with the 4G LTE acting as the backup.  I've setup a track on the static route to the primary ISP.  I'm having multiple issues.  Initially I used the Gig 0/0 int instead of a Loopback address for the IP SLA source.  The IP SLA traffic would be sent to the cellular interface and cause an IP source violation and the interface would flap.  Then I used the Loopback and I could not get the route to fail back when the connection came back up.  Even with the Loopback as the source for IP SLA I'm still getting flapping and I think that is a NAT configuration issue.  I've applied an access-group on the cellular interface to try to fix the ip source violation issues, but it doesn't appear to work.  The IP-SLA-POLICY route map is an attempt to force the IP SLA traffic to the primary interface.  Any help or suggestions would be greatly appreciated.   Here is the relevant config:
chat-script lte "" "AT!CALL1" TIMEOUT 20 "OK"
controller Cellular 0/1
track 150 ip sla 100 reachability
track 250 ip sla 200 reachability
track 400 list boolean or
object 150
object 250
delay down 30 up 30
interface Loopback0
ip address 10.0.40.1 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 67.x.x.x 255.255.255.248  ***/29 From Internet Provider
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.20
description Voice VLAN
encapsulation dot1Q 20
ip address 10.0.20.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.30
description Data VLAN
encapsulation dot1Q 30 native
ip address 10.0.30.1 255.255.255.0
ip nat inside
interface Cellular0/1/0
ip address negotiated
ip access-group 120 out
ip nat outside
encapsulation slip
dialer in-band
dialer string lte
dialer-group 1
async mode interactive
ip local policy route-map IP-SLA-POLICY
ip dns server
no ip nat service sip udp port 5060
ip nat inside source route-map TW interface GigabitEthernet0/0 overload
ip nat inside source route-map VW interface Cellular0/1/0 overload
ip route 0.0.0.0 0.0.0.0 67.y.y.y track 400 ***67.y.y.y. is the Static IP of the Cable Modem
ip route 0.0.0.0 0.0.0.0 Cellular0/1/0 50
ip route 4.2.2.3 255.255.255.255 Cellular0/1/0 ***used for testing cellular interface by pinging 4.2.2.3
ip sla 100
icmp-echo 4.2.2.4 source-interface Loopback0
threshold 350
timeout 400
frequency 5
ip sla schedule 100 life forever start-time now
ip sla 200
icmp-echo 8.8.4.4 source-interface Loopback0
threshold 350
timeout 400
frequency 5
ip sla schedule 200 life forever start-time now
access-list 100 permit ip 10.0.20.0 0.0.0.255 any
access-list 100 permit ip 10.0.30.0 0.0.0.255 any
access-list 100 permit ip host 10.0.40.1 any
access-list 110 permit ip 10.0.20.0 0.0.0.255 any
access-list 110 permit ip 10.0.30.0 0.0.0.255 any
access-list 120 deny   ip 10.0.0.0 0.0.255.255 any
access-list 120 deny   ip 192.168.0.0 0.0.255.255 any
access-list 120 deny   ip 172.0.0.0 0.0.0.255 any
access-list 120 deny   ip host 67.x.x.x any
access-list 120 permit ip any any
access-list 150 permit icmp host 10.0.40.1 host 8.8.4.4 echo
access-list 150 permit icmp host 10.0.40.1 host 4.2.2.4 echo
dialer-list 1 protocol ip permit
route-map VW permit 10
match ip address 110
match interface Cellular0/1/0
route-map TW permit 10
match ip address 100
match interface GigabitEthernet0/0
route-map IP-SLA-POLICY permit 10
match ip address 150
set interface GigabitEthernet0/0
line 0/1/0
script dialer lte
modem InOut
no exec
rxspeed 100000000
txspeed 50000000
tony.bany
I don't know if it's the most efficient, but I was able to get it working by altering the IP-SLA-Policy route-map and inserting a Null Route that became active when the Primary default was removed.
object 150
object 250
delay down 30 up 30
track 600 list boolean and
object 150 not
object 250 not
delay up 30
ip route 67.y.y.y 255.255.255.255 Null0 200 track 600
ip sla 100
icmp-echo 4.2.2.4 source-interface GigabitEthernet0/0
threshold 350
timeout 400
frequency 5
ip sla 200
icmp-echo 8.8.4.4 source-interface GigabitEthernet0/0
threshold 350
timeout 400
frequency 5
access-list 100 permit ip 10.0.10.0 0.0.0.255 any
access-list 110 permit ip 10.0.10.0 0.0.0.255 any
access-list 150 permit icmp host 67.x.x.x host 8.8.4.4 echo
access-list 150 permit icmp host 67.x.x.x host 4.2.2.4 echo
set ip next-hop 67.y.y.y
set interface Null0
I used a simular config without any issues with 3G cards but with 4G cards I'm expiriencing simular issues.
Are you still using same config in the production or you already modified it?
