What is the difference between the two following BGP configs?
caobo1020
My question is what's the fucntion of the empty route-map in the second config?
Config 1:
router bgp 100
  neighbor 1.1.1.1
Config 2:
router bgp 100
  neighbor 1.1.1.1 route-map IBGP-Neighbor-OUT out
route-map IBGP-Neighbor-OUT permit 20
Bo
John Blakley
Technically, config 1 is incorrect. The neighbor command specifies the neighbor and their AS or other parameters that can be applied directly to a neighbor.
Config 2 on the other hand isn't necessary because you're allowing everything out. Route maps have an implicit deny at the end of them. Because this route map doesn't have any match clause, it matches everything, so everything would be allowed out. It's the same as not having a route-map configured on the neighbor.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
