Configuring PPPoE on 897VAM with no IP on /29
ryan.meskill
Hello there-I've had a provider switch from dedicated /29 with static upstream routing to PPPoE with the insistence that we don't now have a next hop. There's a huge language barrier between me and the provider so I need to go through an intermediary so I'm trying to get all my ducks in a row before going back to them. I'm presuming I should be getting a next hop via the PPPoE link, and I *believe* I've established it, but I can't sort out where the IP should be applied and how to configure the routing/nat rules.
sh caller ip
  Line           User       IP Address      Local Number    Remote Number   <->
  Vi2            e14yhnaka-sseu000400 \
                            -               -               <unknown phone  in
sh caller ip
sh caller
                                                  Active    Idle
  Line           User               Service       Time      Time
  vty 10         xxx           VTY           00:53:22  00:00:00
  Vi2            e14xxxxxx-sseu000400 \
                                    PPPoE         00:16:05  00:00:05
interface GigabitEthernet8
 description Internet
 ip address x.x.x.x 255.255.255.248
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nbar protocol-discovery
 ip nat outside
 ip virtual-reassembly in
 zone-member security OUTSIDE
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface Dialer1
 ip address negotiated
 ip mtu 1472
 encapsulation ppp
 dialer pool 1
 dialer idle-timeout 0
 dialer persistent
 dialer-group 1
 no cdp enable
 ppp authentication chap callin
 ppp chap hostname xxxxxXXX@xxx.xx
 ppp chap password 7 xxxXXXxxx
 ppp ipcp route default
 ppp ipcp address accept
That caller is definitely connected and packets are passing, leading me to believe the PPPoE connection is established, but I'm not getting anything in the show caller ip section, am not seeing any routes to pppoe and don't know what else I should be looking for to confirm/connect myself upstream at this point...
The provider says I should have that entire /29 to myself, and I've assigned myself the first IP therein, but I'm not used to not having a peer IP to point traffic at, and am wondering if I'm missing some sort of PPPoE peer. I've tried to assign the public IP to the Dialer1 interface instead, but that didn't give me any success.
ryan.meskill
Ok, in the end it turned out I needed to configure the PPPoE config on Dialer1 and then call it out as an 'unnumbered' interface, with the IP/subnet living on the physical external interface, Gi8:
interface Dialer1
 mtu 1492
 ip unnumbered GigabitEthernet8
 ip mtu 1472
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer persistent
 dialer-group 1
 ppp chap hostname xxxx@xxx.xxx
 ppp chap password 7 xxxxxxx
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
7 Replies 7
the config doesn't look right. You have a zone based firewall (or not) ? Either way, post the full output of
sh run
Indeed, am running a ZBF, with DMVPN for access back to the rest of our network. No VRFs and DMVPN running on Tunnel100. Rough config here:
interface Tunnel100
 tunnel source GigabitEthernet8
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
policy-map type inspect PM_INSIDE_TO_self
 class class-default
  pass
policy-map type inspect PM_self_TO_INSIDE
 class class-default
  pass
policy-map type inspect PM_self_TO_OUTSIDE
 class type inspect CM_CRYPTO
  pass
 class type inspect CM_DHCP
  pass
 class type inspect CM_self_TO_OUTSIDE
  inspect
 class class-default
  drop
policy-map type inspect PM_INSIDE_TO_OUTSIDE
 class type inspect CM_INSIDE_OUTSIDE_INSPECT
  inspect
 class type inspect CM_PROTOCOL_GRE
  pass
 class class-default
  drop log
zone security OUTSIDE
zone security INSIDE
zone security GUEST
zone-pair security INSIDE_TO_OUTSIDE source INSIDE destination OUTSIDE
 service-policy type inspect PM_INSIDE_TO_OUTSIDE
zone-pair security GUEST_TO_OUTSIDE source GUEST destination OUTSIDE
 service-policy type inspect PM_GUEST_TO_OUTSIDE
zone-pair security OUTSIDE_TO_self source OUTSIDE destination self
 service-policy type inspect PM_OUTSIDE_TO_self
zone-pair security INSIDE_TO_self source INSIDE destination self
 service-policy type inspect PM_INSIDE_TO_self
zone-pair security self_TO_INSIDE source self destination INSIDE
 service-policy type inspect PM_self_TO_INSIDE
zone-pair security self_TO_OUTSIDE source self destination OUTSIDE
 service-policy type inspect PM_self_TO_OUTSIDE
ip nat inside source list NAT_RANGE interface GigabitEthernet8 overload
ip access-list standard NAT_RANGE
 permit 172.x.x.x 0.0.0.15
 permit 172.x.x.x 0.0.0.255
 permit 192.168.x.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 Dialer1
what is the inside of the ZBF, the tunnel ? Post the full running config
(sh run)
Is there are any part of your config already working ?
Yes, the config was working perfectly (DMVPN, external ssh access, NAT, tunnels, ZBF, etc) until the provider changed their circuit delivery. Again, in the past we had a /29 with a gateway defined, now they've given us a PPPoE config with no gateway nor peer address to connect to and I'm trying to shoehorn this into the existing config. Uplink is via Gi8, with Tunnel100 being our DMVPN connection (again, working prior to the provider changes). I am attaching a sanitized config, but the ZBF and DMVPN config was fine, I'm just trying to get the PPPoE config setup properly now...
I am not really sure I fully understand what you are running into. If you don't have a default gateway, you just specify the outgoing interface in your default route.
Try the config below (important parts marked in bold)"
config-register 0x2102
version 15.7
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec show-timezone
service timestamps log datetime msec show-timezone
service password-encryption
service sequence-numbers
hostname YOKVPN01
boot-start-marker
boot system flash:c800-universalk9-mz.SPA.157-3.M7.bin
boot system flash:c800-universalk9-mz.SPA.156-3.M6a.bin
warm-reboot
boot-end-marker
no shell processing
aqm-register-fnf
security authentication failure rate 10 log
logging buffered 4096
logging rate-limit 5 except critical
no logging console
no logging monitor
aaa new-model
aaa authentication password-prompt LOCAL_Password:
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authorization config-commands
aaa authorization exec default group tacacs+ local if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ local if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
process cpu threshold type total rising 40 interval 300
service-module wlan-ap 0 bootimage autonomous
no ip source-route
no ip gratuitous-arps
ip options drop
ip nbar protocol-pack flash:/pp-adv-isrg2-154-3.M2-20-15.0.0.pack
no ip bootp server
ip domain timeout 1
ip cef
no ipv6 cef
parameter-map type ooo global
tcp reassembly queue length 512
tcp reassembly memory limit 8192
tcp reassembly alarm off
cts logging verbose
license feature MEM-8XX-512U1GB
license udi pid C897VAM-W-E-K9 sn FCZ181892MJ
license accept end user agreement
archive
log config
logging enable
redundancy
controller VDSL 0
lldp run
class-map type inspect match-any CM_GUEST_OUTSIDE_INSPECT
match protocol dns
match protocol http
match protocol https
match protocol ftp
match protocol tcp
match protocol udp
class-map type inspect match-any CM_self_TO_OUTSIDE
match protocol tcp
match protocol udp
match protocol icmp
class-map type inspect match-any CM_OUTSIDE_TO_self
match access-group name MGMT_ACCESS_EXTERNAL
class-map match-any CM_QOS_QUEUE_CRITICAL_DATA
match dscp af11 af12 af13 cs2 af21 af22 af23
class-map match-any CM_QOS_QUEUE_INTERACTIVE_VIDEO
match dscp cs4 af41 af42 af43
class-map match-any TROJAN
match protocol attribute category trojan
class-map match-any CM_QOS_QUEUE_SCAVENGER
match dscp cs1
class-map match-any CM_QOS_QUEUE_VOICE
match dscp ef
class-map match-any CM_QOS_QUEUE_STREAMING_VIDEO
match dscp af31 af32 af33 cs5
class-map match-any P2P
match protocol attribute sub-category p2p-file-transfer
match protocol attribute sub-category p2p-networking
class-map match-any CM_QOS_QUEUE_NET_CTRL
match dscp cs6
class-map type inspect match-any CM_PROTOCOL_GRE
description Permit GRE traffic via ACL
match access-group name GRE
class-map type inspect match-any CM_DHCP
match protocol bootpc
match protocol bootps
class-map type inspect match-any CM_INSIDE_OUTSIDE_INSPECT
match protocol http
match protocol ftp
match protocol dns
match protocol h323
match protocol smtp
match protocol skinny
match protocol sip
match protocol sip-tls
match protocol l2tp
match protocol pptp
match protocol tcp
match protocol udp
match protocol icmp
class-map match-any CM_QOS_QUEUE_CALL_SIGNALING
match dscp cs3
class-map type inspect match-any CM_CRYPTO
match access-group name CRYPTO_ACCESS
class class-default
pass
class class-default
pass
pass
pass
inspect
class class-default
drop
policy-map type inspect PM_OUTSIDE_TO_self
pass
pass
class type inspect CM_OUTSIDE_TO_self
inspect
class class-default
drop
policy-map PM_QOS_WAN_QUEUE
class CM_QOS_QUEUE_INTERACTIVE_VIDEO
bandwidth remaining percent 30
random-detect dscp-based
class CM_QOS_QUEUE_STREAMING_VIDEO
bandwidth remaining percent 10
class CM_QOS_QUEUE_NET_CTRL
bandwidth remaining percent 5
class CM_QOS_QUEUE_CALL_SIGNALING
bandwidth remaining percent 4
class CM_QOS_QUEUE_CRITICAL_DATA
bandwidth remaining percent 25
class CM_QOS_QUEUE_SCAVENGER
class CM_QOS_QUEUE_VOICE
priority level 1
police cir percent 10
class class-default
random-detect
inspect
pass
class class-default
drop log
policy-map LAN_POLICY
class P2P
drop
class TROJAN
drop
policy-map type inspect PM_GUEST_TO_OUTSIDE
class type inspect CM_GUEST_OUTSIDE_INSPECT
inspect
class class-default
drop log
policy-map POLICY_TRANSPORT_1
class class-default
shape average 50000000
service-policy PM_QOS_WAN_QUEUE
description Internet facing Interface
description inside user data network
zone security GUEST
description Inside Guest data network without access to PQ
interface Loopback0
ip address x.x.x.x 255.255.255.255
interface Tunnel100
bandwidth 50000
ip address 192.168.x.x 255.255.254.0
no ip redirects
ip mtu 1440
ip nhrp authentication earphone
ip nhrp network-id 100
ip nhrp nhs dynamic nbma x.x.x.x
zone-member security INSIDE
ip tcp adjust-mss 1360
nhrp group RS_GROUP_50MBPS
tunnel mode gre multipoint
tunnel key 100
tunnel protection ipsec profile DMVPN_IKEV2_IPSEC_PROFILE
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
shutdown
--> no interface Dialer1
mtu 1492
ip mtu 1472
encapsulation ppp
dialer pool 1
dialer persistent
dialer-group 1
no cdp enable
interface GigabitEthernet0
switchport access vlan 10
switchport voice vlan 15
no ip address
spanning-tree portfast
interface GigabitEthernet1
switchport access vlan 60
switchport trunk native vlan 60
switchport trunk allowed vlan 1,2,60,70,90,1002-1005
switchport mode trunk
no ip address
power inline never
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
media-type rj45
no cdp enable
service-policy output POLICY_TRANSPORT_1
--> no pppoe enable group global
--> no pppoe-client dial-pool-number 1
interface Wlan-GigabitEthernet8
switchport trunk native vlan 10
no ip address
router bgp 6xxxx
bgp log-neighbor-changes
timers bgp 10 30 30
neighbor DMVPN_US peer-group
neighbor DMVPN_US remote-as 1xxx
neighbor DMVPN_US local-as 6xxxx no-prepend replace-as
neighbor DMVPN_UK peer-group
neighbor DMVPN_UK remote-as 2xxxx
neighbor DMVPN_UK local-as 6xxxx no-prepend replace-as
neighbor x.x.x.x peer-group DMVPN_US
neighbor x.x.x.x peer-group DMVPN_UK
address-family ipv4
network x.x.x.x mask 255.255.255.255
network x.x.x.x mask 255.255.254.0
neighbor DMVPN_US soft-reconfiguration inbound
neighbor DMVPN_US prefix-list DENY_DEFAULT_ROUTE in
neighbor DMVPN_US route-map DMVPN_SPOKE_IN in
neighbor DMVPN_UK soft-reconfiguration inbound
neighbor DMVPN_UK prefix-list DENY_DEFAULT_ROUTE in
neighbor DMVPN_UK route-map DMVPN_SPOKE_IN in
neighbor x.x.x.x activate
exit-address-family
address-family ipv4 multicast
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip bgp-community new-format
ip community-list standard US_ROUTES permit 1xxx:100
ip community-list standard UK_ROUTES permit 2xxxx:100
ip community-list standard UK_PREF_ROUTES permit 2xxxx:200
ip community-list standard UK_DEFAULT_ROUTE permit 2xxxx:999
ip community-list standard US_DEFAULT_ROUTE permit 1xxx:999
ip community-list standard UK_ONLY_ROUTES permit 2xxxx:300
ip as-path access-list 100 permit ^17493$
sort-by bytes
ip dns view default
domain timeout 1
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet8
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
permit
ip access-list standard SNMP_RO
permit
deny any
permit
deny any
ip access-list extended ADMIN_ACCESS
permit tcp host x.x.x.x any eq 22
ip access-list extended CRYPTO_ACCESS
permit esp any any
permit udp any any eq isakmp
permit udp any any eq non500-isakmp
ip access-list extended GRE
remark Allow GRE (used by PPTP)
permit gre any any
ip access-list extended MGMT_ACCESS_EXTERNAL
permit icmp any any echo-reply
permit icmp x.x.0.0 0.0.255.255 any echo
permit icmp any any packet-too-big
permit icmp any any traceroute
permit icmp any any unreachable
permit icmp any any host-unreachable
permit icmp any any time-exceeded
permit tcp x.x.0.0 0.0.255.255 any eq 22
deny ip any any
ip prefix-list DENY_DEFAULT_ROUTE permit 0.0.0.0/0 ge 1
logging trap warnings
logging origin-id hostname
logging source-interface Loopback0
ipv6 ioam timestamp
route-map DMVPN_SPOKE_IN permit 10
match community US_DEFAULT_ROUTE
set local-preference 200
route-map DMVPN_SPOKE_IN permit 15
match community UK_DEFAULT_ROUTE
route-map DMVPN_SPOKE_IN permit 20
match community UK_PREF_ROUTES
route-map DMVPN_SPOKE_IN permit 30
description By default use US hubs
match community US_ROUTES
route-map DMVPN_SPOKE_IN permit 40
match community UK_ROUTES
set local-preference 50
snmp-server ifindex persist
snmp-server trap-source Loopback0
snmp-server location location
snmp-server contact Network Engineering & Operations - network@proquest.com
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps eigrp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps license
snmp-server enable traps envmon
snmp-server enable traps flash insertion
snmp-server enable traps flash removal
snmp-server enable traps bfd
snmp-server enable traps bgp
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps hsrp
snmp-server enable traps cpu threshold
access-list 100 remark Permit DHCP Traffic through packet spoof filter
access-list 100 permit udp any eq bootps any eq bootpc
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
logging synchronous
no modem enable
transport preferred none
line aux 0
logging synchronous
line vty 0 4
logging synchronous
transport input ssh
transport output telnet ssh
line vty 5 15
logging synchronous
transport input ssh
line 2
no activation-character
no exec
transport input all
stopbits 1
scheduler allocate 20000 1000
ntp update-calendar
end
I'm not clear if I'm missing something from the provider, but I have the following:
-PPPoE username/password
-/29 for me to assign as my WAN IP
Removing Dialer1 and the PPPoE config will fail to have this connect and, as I don't have a next hop, I won't have anywhere to go. My thought was to configure Dialer1 with the PPPoE config and then set Dialer1 as my next hop, but I'm unclear about two things:
-where to put the WAN IP: on Dialer1 or Gi8
-why when I configured things as above and got an initial PPPoE connection I never got a proper connection or any upstream traffic when setting Dialer1 as my next hop.
From what I understand I don't need an IP for the PPPoE peer in order to establish the connection, but shouldn't I expect to get one once it establishes so my router knows where to send traffic? As I am getting a /29 for my WAN IP range I suppose I don't need to configure my interfaces to get their IP from DHCP, but I'm still not clear on what the correct config should be for this type of setup. Additionally unfortunately I am not on-site and therefore I need to gather plans before I am able to test them.
ryan.meskill
interface Dialer1
 mtu 1492
 ip mtu 1472
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer persistent
 dialer-group 1
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 duplex auto
 speed auto
 media-type rj45
 no cdp enable
