Configuring PRI for Backup
bapatsubodh
Is it possible to configure PRI (ISDN) lines as a back up to 64 kbps leased lines ? At one location if leased line fails is it possible to initiate a call from PRI line to a BRI line where leased line has failed ? I am able to manually establish a call to that location by " isdn test call .... " command. But I am not able to route traffic on this link either by backup or by adding static routes manually.
Any link on cisco.com / or sample conf. is appreciable.
Thanx in advance.
Subodh
globalnettech
Level 5
Level 5
Hello Subodh,
this should certainly be possible. The configuration would basically look like this:
interface Serial0:15
ip address 10.1.1.1 255.255.255.252
backup interface BRI0
no ip route-cache
interface BRI0
backup interface Serial0:15
dialer map ip 192.168.1.2 name REMOTE1 broadcast 1234
dialer-group 1
encapsulation ppp
no ip route-cache
no ip mroute-cache
load-interval 30
no keepalive
isdn switch-type basic-net3
no fair-queue
no cdp enable
ppp authentication chap
ip route 0.0.0.0 0.0.0.0 10.1.1.2
ip route 0.0.0.0 0.0.0.0 192.168.1.2 200
What do you have configured right now ?
GNT
