Configuring QoS Policy Propagation via Border Gateway Protocol Question
idn.wanggang
Dear sirs:
In the document http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfprop.htm
The last task of Policy Propagation via BGP Configuration is Classifies packets using IP Precedence in a interface,but the configuration example has no this step,why not?
Best regard
spremkumar
Level 9
Level 9
hi
As you pointed out in QoPPB you can configure/translate the bgp attribute values into either a qos-group or ip-prec.
As metnioned in the link it does contain 3 steps in doing that ...i.e.,
1.creating route map
2.applying the route map to bgp routes transferred
3.enabling per interface packet marking
interface x
bgp-policy |source,destination| ip-prec-map
or
bgp-policy |source,destination| ip-qos-map
do find the 3 rd step which shows how the same is configured/applied on the interfaces..
regds
