CONFIGURING REDUNDANCY WITH TWO SERVICE PROVIDERS
nicholasgondwe
Hi I have a 1721 router with two interfaces
One 1ENET and a DB60 serial interface to two different service providers with two different Ip addresses. I also have a single fa0 interface which connects to the LAN. I need this LAN to NAT and connect to the internet via one of the interfaces and in the event of a failure of one of the interfaces it should fall on the other service provider link. How best do I achieve this to ensure connectivity at all times. I also do not need load balancing so I guess I can use floating static routes as I have only static routes in operation.
Hi Nicholas,
You can use floating static routes to do Active/Standby routes.I would concern about Nat for this.You should use route-map commands to tell the router what's the right interface that we want to do Nat functions. Because of the nat operations will do what we defined.The router doesn't care about what is the active interface at that time.
Hopes this helps
Thot
paolo bevilacqua
Hi, here is a configuration example that does what you're asking:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a00808d2b72.shtml
