Configuring Xconnect on Cisco 3750 L3 Switch
lmanavalan
I have a situation where i am not able configure the xconnect l2tp tunnel on a Cisco 1841 router due to MTU size of 1546 (cannot defragment).
So i am looking to configure the L2TP on the Cisco Layer 3 Switch.
Is this possible to do it on the Layer 3 Switch or if their a way to overcome the big MTU on the cisco router.
regards
Logesh
5 Replies 5
Vinit Jain
Hello Logesh
Are you talking about L2tpv3 or just the L2tp tunneling protocol. L2tp tunneling is supported on 3750 switch where as i think there is no support for l2tpv3 on 3750. ME-3750 do support L2tpv3.
i tried it on 3750 running 150-2.SE9 image and dont see the command supported.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_25_see/configuration/guide/scg/swtunnel.html
Cisco1800 series router do not support higher MTU settings.
R4(config)#int fa0/0
R4(config-if)#mtu 2000
% Interface FastEthernet0/0 does not support user settable mtu.
R4(config-if)#ip mtu ?
  <68-1500>  MTU (bytes)
Hope this helps.
Vinit
--Vinit
Thanks for your reply.
Unfortunately I cannot use the 802.1q tunnelling because its not purely switch environment.
I have core router I need to pass through.
regards
Logesh
Hi Logesh,
I dont think you have much option. The only other option (if you cant use lower MTU) would be to use a different router.
Please let me know if you have any other questions.
Vinit
PS: Please mark the question as answered if ur query has been resolved. Also, please rate useful posts.
--Vinit
I tried with the Cisco 1841 but I am not able to alter the MTU size.
It a requirement that I cannot defragment the MTU.
regards
Logesh
Hello Logesh
As mentioned before, you cannot increase the MTU on 1841 router. For higher MTU support, you will have to use a different router and thus the suggestion to upgrade the router from 1841 to a different one.
Vinit
--Vinit
