Showing results forĀ
Search instead forĀ
Did you mean:Ā
Windows NLB with Cisco Devices
ssweehinlew
There is no ping reply when pinging to the cluster IP for  Windows Network load balancer from external network. Below command has been added to the L3 switch and internet router.
Ping from Local network, it is working fine. There is the reply from Cluster IP. Any advice this issue?
Switch
  • STATIC ARP RESOLUTION Cisco Global command mode
    For example:
    arp [ip] [cluster multicast mac] ARPA
    arp 192.168.1.100 03bf.c0a8.0164 ARPA
  • STATIC MAC RESOLUTION Cisco Global command mode
    For example:
    mac-address-table static [cluster multicast mac] [vlan id] [interface]
    mac-address-table static 03bf.c0a8.0164 vlan 1 interface GigabitEthernet1/1 GigabitEthernet1/2
    GigabitEthernet1/15 GigabitEthernet1/16
Router
arp ip-address hardware-address type [alias]
0 Replies 0
