Confirmation of free space on cisco router before ios upgrade
jomo frank
Hello Expert,
We are considering upgrading our 3945 router ios to 15.4(T), I am unsure how to verify the router's flash free space.
Could you provide some guidance.
Head_office#sh ver
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9 EASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 18-Jul-10 06:43 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SO
-#- --length-- -----date/time------ path
1 55277232 Oct 02 2010 13:13:26 c3900-universalk9-mz.SPA.150-1.M3.bin
2 2903 Oct 02 2010 13:26:44 cpconfig-39xx.cfg
3 2915328 Oct 02 2010 13:26:54 cpexpress.tar
4 1038 Oct 02 2010 13:27:04 home.shtml
5 115712 Oct 02 2010 13:27:10 home.tar
6 1697952 Oct 02 2010 13:27:26 securedesktop-ios-3.1.1.45-k9.pkg
7 415956 Oct 02 2010 13:27:38 sslclient-win-1.1.4.176.pkg
8 8654 Nov 29 2010 19:31:18 SDM_Backup
9 840 Nov 08 2018 20:39:12 vlan.dat
199704576 bytes available (60469248 bytes used)
I checked, the latest 15.4.2T4(ED) release is about 95Mb.
So you have enough space to load a second IOS.
Just in case, to configure the router to boot the new IOS use the following config:
boot system flash:c3900-universalk9-mz.SPA.154-2.T4.bin
boot system flash:c3900-universalk9-mz.SPA.150-1.M3.bin
boot system flash:
This way it should boot to the new IOS, but if something fails, it will then boot off the original, and the last statement just says, find any IOS in flash and use that.
7 Replies 7
chrihussey
It looks like the router has the default 256Mb of flash of which about 60Mb has been used and there is close to 199 Mb available.
It never is exact when you add it up, but the "199704576 bytes available (60469248 bytes used)" from the "dir flash" output shows this.
Also, the full post of "sh ver" shoulod have a line about ATA System CompactFlash which provide some additional info.
Hope this helps
Hello chrihussey
I included the full sh ver for your guildance
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.0(1)M3, RELEASE SOFTWARE (fc2)
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
Head_office uptime is 46 weeks, 2 days, 53 minutes
System image file is "flash0:c3900-universalk9-mz.SPA.150-1.M3.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3945-CHASSIS (revision 1.1) with C3900-SPE150/K9 with 983040K/65536K bytes of memory.
Processor board ID FTX1440AKUL
4 FastEthernet interfaces
3 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 C3900-SPE150/K9 FOC14356BN7
Technology Package License Information for Module:'c3900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc None None None
data None None None
You have 256Mb of flash:
and according to the previous output, you have about 199Mb of available space for the new IOS.
Hello chrihussey,
Thanks for the clarification.
Do you know the size of the 15.4(T) IOS ?
boot system flash:
Hello
Thank you very much for all the assistance.
Leo Laohoo
Be very careful when using the "T" train.  "T" train is well known to be very unstable.
