Conflict between static and dynamic NAT from two # pools
Tshi M
Level 5
Level 5
Hi all,
I have a Cisco 6509 with connections to multiple venues. Both destinations require that I NAT my internal network to their assigned IP. The problem is that one of their venue require one to one translation. When I do this, the host with the static NAT is unable to connect to the venue that does not request the one to one NAT. Below is the relevant configuration:
For Venue not requesting one to one NAT:
ip access-list extented CMX_NAT
permit ip 10.1.21.0 0.0.0.255 199.2.14.0 0.0.0.15
permit ip 10.1.31.0 0.0.0.255 199.2.14.0 0.0.0.15
permit ip 10.1.32.0 0.0.0.255 199.2.14.0 0.0.0.15
ip nat pool Dynamic-Pool 10.20.22.2 10.20.22.14 prefix-length 28
ip nat inside source route-map CMX_map pool Dynamic-Pool
route-map CMX_map permit 10
match ip address CMX_NAT
For Venue requesting one to one NAT
ip access-list ext BMX_NAT
permit ip 10.1.21.0 0.0.0.255 192.168.25.25 0.0.0.0
permit ip 10.1.31.0 0.0.0.255 192.168.25.25 0.0.0.0
permit ip 10.1.32.0 0.0.0.255 192.168.25.25 0.0.0.0
ip nat pool BMX_pool 10.10.89.245 10.10.89.254 prefix-length 28
ip nat inside source route-map BMX_map pool BMX_pool
ip nat inside source static 10.1.31.240 10.10.89.242
ip nat inside source static 10.1.21.227 10.10.89.243
route-map BMX_map permit 10
match ip address BMX_NAT
Because of the one to one NAT, 10.1.21.227 and 10.1.31.240 can no longer access the CMX venue.
Peter Koltl
Level 7
Level 7
IOS NAT table entries contains only 4 fields:
R101#sh ip nat tr
Pro Inside global      Inside local       Outside local      Outside global
--- 10.10.89.243       10.1.21.227        ---                ---
--- 10.10.89.242       10.1.31.240        ---                ---
On the contrary, ASA NAT table entries also contain the ACL in case of policy NAT so an ASA could cope with such a situation easily.
So my assumption is that IOS is unable to handle the incoming packet from CMX as the route-map is not referenced in the NAT table.
Maybe you could try to translate CMX addresses too with a destination NAT.
