Confusion on wildcard masks
greekgeek
What exactly is the wildcard mask doing in this line:
access-list 10 deny 192.168.10.128 0.0.0.31
Mohamed Sobair
Level 7
Level 7
Hi Guys,
For the Wildcard mask, I have a best practise to calculate it as follows:
1- you take the original Subnetmask of the Network ID and Subtract it by(255.255.255.255).
Example:
you have the Network : 192.168.10.128/27
192.168.10.128 255.255.255.224
** always take (255.255.255.255) -
(255.255.255.224)
equals = 0.0.0.31 (wildcard mask)
So the wildcard mask for 192.16.10.128/27
equals 192.168.10.128 0.0.0.31, which will match 31 bit hosts from 129 - 159.
Note: the last octet 159 is the broadcast of the subnet & its included in the calculation.
Mohamed Sobair
purohit_810
Level 5
Level 5
It will deny all IP address start from
192.168.10.128 to 139 {129 and 140 both will comver}
Block size is 0 to 31 mean it covers 32 Ip address.
Dharmesh Purohit
The host range should be 192.168.10.129 to 192.168.10.158 which will be denied. Or i understood it wrong. 192.168.10.128/27
Purohit,
I guess it is a typo. Shouldn't it be 192.168.10.128 to 159 ?
regards,
Mohamed Sobair
Level 7
Level 7
Hi Guys,
Example:
(255.255.255.224)
Mohamed Sobair
