Confusions in ATM
ratnesh.nagori
Hi folks,
I am a new member here and this is my first post.
Right now I am studying ATM and have lots of confusions. ATM communication happens through VPI/VCI. What are these and what is there significance.
What is a PVC ?
Also, how can we configure multiple pvcs on single atm interface, if you need number, it is 2000 PVCs. How can we do that.
Please reply with the config also (just gimme an example, i will be able to understand).
What is IMA ? Please provide details.
I will really appreciate your help.
Thanks in advance
Ratnesh
5 Replies 5
jpl861
Level 4
Level 4
I'll try to answer your questions base on what we are doing.
Usually, these VPI/VCI pairs are the layer2 identifier when trasmitted over the ATM switches (i.e. MGX 8850s or Lucent PSAX). A PVC as the name implies is a Permanent Virtual Circuit so it means permanent. VPI/VCI is like the DLCI of a Frame-relay circuit. Just like frame-relay, ATM also has point-to-point subinterfaces and multipoint subinterfaces. You can create multiple point-to-point subinterfaces if you want to have multiple point-to-point virtual circuits. Same as a multipoint, a multipoint sub-if can have multiple neighbors or peers on a single subinterface.
I don't know if you are sure to make 2000 VCs on a single ATM interface as it will be pain in the butt. When the interface goes down, all 2000VCs will also go down. And you will defin need a very powerful router to do that and I do not know if there is one. (I'm guessing on this part as I haven't read the white paper or data sheet of the routers)
HTH,
John
Hi John,
Yes the router I am using is a powerfull one .
Can you please reply with config, how to create the PVC on ATM interface ?
Ratnesh
Hello Ratnesh,
there are features that can be of help in your scenario like ILMI PVC discovery.
ILMI is the protocol spoken between a router ATM DTE interface and the connected ATM switch port.
see
Configuring PVC Discovery Example
The following example shows how to enable PVC Discovery on an ATM main  interface 2/0. The keyword subinterface is  used so that all discovered PVCs with a VPI value of 1 will be assigned  to the subinterface 2/0.1. For further information, refer to the section  "Configuring  PVC Discovery" earlier in this chapter.
interface atm 2/0
 pvc RouterA 0/16 ilmi
 exit
 atm ilmi-pvc-discovery subinterface
 exit
interface atm 2/0.1 multipoint
 ip address 172.21.51.5 255.255.255.0
see
http://www.cisco.com/en/US/docs/ios/atm/configuration/guide/atm_cfg_atm_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1005115
Other possible tools for scalability can be the VC classes
If you look at the document from the beginning you will see that configuration ranges from a totally manual
configuration where the network admin specifies the PVC to be used and what remote device can be
reached on that specific VPI/VCI value.
At the other end there are the VC classes and the ILMI PVC autodiscovery features that takes advantage
of ATM signalling protocols for forms of auto-provisioning.
Another important note is the following:
each Cisco router platform has a limit on the maximum number of interfaces (including physical
and logical interfaces like loopbacks or tunnels) that can be configured on device.
Devices like C10000, C6400, or C7200 with specific license have an increased IDB count to deal
with high  number of subinterfaces
see
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a0080094322.shtml
so not all platforms could support 2000 ATM subinterfaces.
To be noted that using multipoint  ATM subinterfaces one subif is associated to multiple
and potentially many ATM PVCs as shown in ATM ILMI PVC discovery example.
Hope to help
Giuseppe
paolo bevilacqua
Why don't you start reading some books and the documentation ?
Hi Ratnesh,
Here's an example of point-to-point PVC.
RouterA:
interface ATM1/0.108 point-to-point
bandwidth 12500
ip address 10.200.20.137 255.255.255.252
ip accounting output-packets
delay 101
pvc 80/108
  protocol ip 10.200.20.138 broadcast
  vbr-nrt 2470 2470
  oam-pvc manage 3
  oam retry 3 3 1
  encapsulation aal5snap
RouterB:
bandwidth 12500
ip address 10.200.20.138 255.255.255.252
delay 101
pvc 20/108
  protocol ip 10.200.20.137 broadcast
  vbr-nrt 2470 2470
  oam-pvc manage 3
  oam retry 3 3 1
HTH,
John
