Connect management port to same switch
Tosj Reiling
Hi all!
I have multiple 2960's and connected their dedicated management port to a switch (2960X) for easier access.
Each management port on the 2960's have a IP in the 10.32.3.0/24 network.
I'm able to connect to all the management ports via SSH from a operations client (other VLAN).
Currently I have the issue that I can't connect to the management port of the switch where all the management ports are connected to.
The management port of the switch (10.32.3.16) is connected to the switch itself.
However I can't SSH into this management port.
I've a included a small mock-up of the network infrastructure below
20 Replies 20
fbabashahi
do you have access-list ?
I did not set access-lists  yet, I need to create one?
no i don't think so i asked because i think maybe the access-list prevent to connect to switch. in your diagram i see you connect that switch to pfsense are you sure about the pfsense config ?
The PFSense config is correct when I connect a client to the "Switch" I can ping it from the Operations client through the PFSsense.
Eg.: Operations Client (10.32.22.101) can ping to Switch Client (10.32.3.101), the Operation client can also ping the management IP of the all the management ports. Except the management port of the "Switch"-switch itself.
If it is ok  please put core switch and the switch here , i hope can help in that way
You mean the running configs?
yes
Running config from the Core:
version 16.6
no service pad
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname SERVER
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
switch 1 provision ws-c3850-24p
switch 2 provision ws-c3850-24p
ip routing
ip domain name *.corp
cpp system-default
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
username admin privilege 15 password 7 ******************
redundancy
 mode sso
interface Port-channel1
 description PFSense Master LACP
 switchport mode trunk
interface Port-channel2
 description DHCP-Server LACP
 switchport mode access
interface Port-channel3
 description PFSense Slave LAPC
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 ip address 10.32.3.11 255.255.255.0
 speed 1000
 negotiation auto
interface GigabitEthernet1/0/1
 switchport access vlan 22
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/9
 channel-group 2 mode active
interface GigabitEthernet1/0/23
 switchport access vlan 21
interface GigabitEthernet1/1/1
 channel-group 1 mode active
interface GigabitEthernet1/1/2
 channel-group 3 mode active
interface GigabitEthernet1/1/3
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/9
interface GigabitEthernet2/1/1
interface GigabitEthernet2/1/2
interface Vlan1
 description SERVER
 no ip address
interface Vlan21
 description MANAGEMENT
 no ip address
interface Vlan22
 description OPERATIONS
 no ip address
interface Vlan68
 description Alarm VLAN
 no ip address
interface Vlan900
 description VoIP VLAN
 no ip address
ip default-gateway 10.32.1.1
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http secure-client-auth
ip route vrf Mgmt-vrf 0.0.0.0 0.0.0.0 10.32.3.1
ip ssh version 2
control-plane
 service-policy input system-cpp-policy
line con 0
 privilege level 15
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 privilege level 15
 login local
 transport input ssh
line vty 5 15
 privilege level 15
 login local
 transport input ssh
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
Running config from the Switch:
version 15.2
no service pad
hostname SWITCH
boot-start-marker
boot-end-marker
enable secret 5 ***********************
enable password **********************
username admin privilege 15 password 0 ***********************
username web privilege 15 password 0 *************************
aaa new-model
aaa session-id common
switch 1 provision ws-c2960x-24ts-l
ip routing
ip domain-name *.corp
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
 ip address 10.32.3.16 255.255.255.0
 no ip route-cache
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
 no ip address
ip default-gateway 10.32.3.1
ip http server
ip route 0.0.0.0 0.0.0.0 10.32.3.1
no vstack
line con 0
line vty 0 4
 privilege level 15
 transport input telnet ssh
line vty 5 15
 privilege level 15
ntp server pool.ntp.org
pnp profile pnp_cco_profile
 transport https host devicehelper.cisco.com port 443
end
Hi again , does your int gig0/0 on core connect to fastethernet 0 , doesn't it? if the answer is yes , i think the problem is because of vrf , you put vrf on one side
if the answer is no , please tell me from which port you need to reach to the destination
speed 1000
negotiation auto
Port Gi0/0 (10.32.3.11) from the core connects to port a port on the "Switch" eg. Gi1/0/3
Port Fa0 (10.32.3.16) from the "Switch" connects to a port on the "Switch" eg. Gi1/0/7
The "Switch" has an direct uplink to the PFSense on port Gi1/0/24
Hi , do you config vrf on both side ? another thing in your line vty config where is login local?
create static arp entries in GRT and vrf... for 10.32.3.11 and 10.32.3.16
I've added the following arp entries:
arp 10.32.3.11 7001.b501.c400 arpa
arp 10.32.3.16 0072.7809.0d00 arpa
But it doesn't seem to work?
L01_01(config)#arp ?
A.B.C.D IP address of ARP entry
vrf Configure static ARP for a VPN Routing/Forwarding instance
