Connect management port to same switch
Tosj Reiling
Hi all!
I have multiple 2960's and connected their dedicated management port to a switch (2960X) for easier access.
Each management port on the 2960's have a IP in the 10.32.3.0/24 network.
I'm able to connect to all the management ports via SSH from a operations client (other VLAN).
Currently I have the issue that I can't connect to the management port of the switch where all the management ports are connected to.
The management port of the switch (10.32.3.16) is connected to the switch itself.
However I can't SSH into this management port.
I've a included a small mock-up of the network infrastructure below
20 Replies 20
I think I did that or am I mistaken?
you shoud create arp entries in vrf also
I don't have the Mgmt-vrf on my 2960X's, I think I created the arp entries on my core (3850) in the Mgmt-vfr and I also created the entry in my 2960X.
Below is the show arp:
"Switch"-switch
SWITCH(config)#arp vrf Mgmt-vrf 10.32.3.11 7001.b501.c400 arpa
% IP routing table Mgmt-vrf does not exist. Create first
SWITCH(config)#arp 10.32.3.11 7001.b501.c400 arpa
SWITCH#show arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.32.3.1               1   b496.9139.5879  ARPA   FastEthernet0
Internet  10.32.3.11              -   7001.b501.c400  ARPA
Internet  10.32.3.16              -   00bf.77a2.9c39  ARPA   FastEthernet0
Internet  10.32.3.101             0   80fa.5b57.da74  ARPA   FastEthernet0
SWITCH#ping 10.32.3.16
Sending 5, 100-byte ICMP Echos to 10.32.3.16, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/3 ms
SWITCH#
Core-switch:
SERVER(config)#arp vrf Mgmt-vrf 10.32.3.16 00bf.77a2.9c39 arpa
SERVER(config)#arp 10.32.3.16 00bf.77a2.9c39 arpa
SERVER(config)#do show arp
SERVER(config)#do show arp vrf Mgmt-vrf
Internet  10.32.3.1               0   b496.9139.5879  ARPA   GigabitEthernet0/0
Internet  10.32.3.11              -   7001.b501.c400  ARPA   GigabitEthernet0/0
Internet  10.32.3.101             0   80fa.5b57.da74  ARPA   GigabitEthernet0/0
SERVER#ping 10.32.3.16
Success rate is 0 percent (0/5)
As you can see I can ping the Management Port on the "Switch"-switch from the Switch terminal, but I can't acess it from my core.
Hello
Hasn't this already been solved by Jon via this post
Kind Regards
Paul
Hey paul
No this is another issue around the same subject, but I thought it would be easier to create a new discussion around this matter.
CSCO11304974
Native VLAN assigned in this switch IP: 10.32.3.16
