Connect Server to Two Router
pm1375pm78722
I have topology like below and I want to my server be accessible from both router, But I don't have any Idea how to Set default gateway in my Server.
you could configure both routers with HSRP, if that is an option. The configs would look like below. A DHCP server has been configured on R2, so on the PC, just enable DHCP...
PT file is attached...
R1
hostname R1
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
standby 1 ip 192.168.1.1
standby 1 priority 110
standby 1 preempt
R2
hostname R2
ip dhcp excluded-address 192.168.1.1 192.168.1.3
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip address 192.168.1.3 255.255.255.0
duplex auto
speed auto
R1
hostname R1
duplex auto
speed auto
standby 1 preempt
R2
hostname R2
ip dhcp pool LAN
duplex auto
speed auto
Hello
If you wish for all 3 device just to be able to reach each other, Then give each device an ip address in the same subnet.
example:
rtr 1
int x/x
ip address 10.1.123.1 255.255.255.0
rtr2
int x/x
ip address 10.1.123.2 255.255.255.0
server
ip  10.1.123.3
subnet mask 255.255.255.0
Kind Regards
Paul
The only possible way is to use the HSRP configuration as informed.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
on a real (non Packet Tracer) router, GLBP and VRRP would be options as well. Unfortunately, Packet Tracer only supports HSRP...
