Connecting 2 2621XM with two modems as a backup
kaliga2008
Hi all,
Am facing a little confusion.
Here the point :
I have 2 2621XM with 2 WIC 2 A/S to connect using a LL and 2 modems. this connection is just a backup to an existing E1 link.
Is it necessary to configure my serial interfaces on async mode ?
First i used 2 SS-RS232 DCE cables but it does nt work, the interface is continuosly on reset status. I think I need DTE cables, is it true ?
Thanks for ur assistance.
Best Regards
paolo bevilacqua
Yes, you need DTE cables to connect the modems. sync or async depends on the type of the modem.
Thanks for the precision. Am waiting the delivery of these cables.
what dp u mean by it depends on the type of the modem?
Thanks for ur help.
Type of modem, sync or asynch ?
