10-01-2014 07:33 PM - edited 03-04-2019 11:52 PM
let me explain further.
My Cisco 3650 connected to a vendor Ethernet switch at 100 meg full duplex. Wan circuit is 10 meg. Will I experience any issues doing this?
Solved! Go to Solution.
10-01-2014 07:54 PM
Asking if you will experience "any" issues is a very broad question. My initial answer is that if you try to send 30 meg of data that yes you will experience issues. But the issue is not with the interface itself but is with the rate limiting that the provider is doing.
The more practical answer is that no you will not experience problems with the switch or the switch interface. 100 meg describes the signaling rate of the interface or the speed at which it will clock the bits that it transmits and not the throughput of the interface. Your interface at 100 meg will connect to the vendor at 100 meg and the rate at which data actually flows will be controlled by the vendor.
Rick
10-01-2014 07:54 PM
Rick
