Connecting my 1751 Router and Nat
terrythompson
I disconnected my ethernet cable from my computer and connected it to port E0 on my router. Applied the ip address 192.168.2.253 /24 recieved a up/up , applied the ip address 192.168.3.1 to FA 0 and received a up/up connected the other end of the cable to a Cisco Switch Port fa 0/24 with a ip address of 192.168.3.3 /24 . Connected a computer to one of the switch port and I can ping pass e0 on the router. I've configured NAT several times in the past w/o any issues. Any ideas what I'm missing?
spremkumar
Level 9
Level 9
can u throw some more light on your problem which ur currently facing and also try to post out ur config so that it will be easy to analyse and feed our inputs..
regds
Router# r sh run
Building configuration...
Current configuration : 600 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
memory-size iomem 15
ip subnet-zero
interface FastEthernet0/0
ip address 192.168.3.1 255.255.255.0
ip nat inside
speed auto
interface Ethernet1/0
--More-- ip address 192.168.2.253 255.255.255.0
ip nat outside
half-duplex
ip nat inside source list 10 interface Ethernet1/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.3
no ip http server
access-list 10 permit 192.168.3.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
no scheduler allocate
end
Router#
