09-01-2005 03:53 AM - edited 03-03-2019 10:24 AM
Please help me in this scenario .
The Scenario is,
i hav PIX 515E with 2 fastethernet ports 100 Mpbs.
and a 4503 switch with supervisor engine IV. and a module with 6 fiber ports,
All 6 fiber ports have been used
Now i want to connect PIX with switch , but the problem is that we r short of ports
If i buy a GBIC and connet to the fast ethernet PIX than the question is "Will there is any issue of speed mismatch ???? "
or
"Can we decrease the Speed of GBIC 5483 to 100 Mpbs ?? "
or please suggest me any other solution.
09-01-2005 02:05 PM
You can get the 5483 and set the speed and duplex. I think the 4503 is running IOS like CLI.
int gi 0/1
speed 100
duplex full
On the PIX
int e0 100full
09-01-2005 08:48 PM
Thanks Shanky , for ur reply, but the problem is i hav read many docs but no say that u can degrade the speed of 5483 to 100 Mbps , I have concerned on it. Please tell me , Have u run those commands on GBIC specially Speed 100
09-01-2005 09:57 PM
You cannot change the speed or duplex on GBIC module. It only works on 1000 MBPS.
regards,
-amit singh
09-01-2005 10:15 PM
Thanks Amit, now can u give me feasible suggestion , so that i connect my 4503 to PIX 100 Mpbs.
Thnaks
Syed Umair Ali
09-01-2005 10:46 PM
Hi Syed,
You have only 2 options:
1 Get an ethernet module for your 4503 with 10/100/100 ports which can be configured for speed/duplex.
2. Try connecting another switch if you have a spare one with the fiberuplink to your 4503 fiber module and then connect the PIX to the switch. Set the gateway on your Switch as the PIX.
regards,
-amit singh
09-02-2005 02:10 AM
Thanks again Amit , if i conect PiX to my access switch that is 2950 thru 100 M link .
Will there be no security concern , ok than i will put that link in other VLAN or something else plz suggest
And Please tell me can acl works with 2950 ?
Thanks again
09-02-2005 03:16 AM
Syed,
You can put your fiber and fix connection into a different vlan. Yes ACL works on 2950 switch and only with enhanced immage.
regards,
-amit singh
