Connecting Three Networks....
woodjl1650
Seems like I spend more and more time in here (Cisco Forums)....
I was talking to a guy today that was trying to help me link my three networks together, so each is sperate but able to talk to each other.  Right now I have them all connect via my ASA, but not able to ping or talk to any of the.  He mention that I could connect them all via a switch and then they should work.
I am new to this world, and having a hard time trying to figure out how to accomplish this.
Right now my network is as follows:
Like I stated before, I want to keep each network seperate, but want to be able to access each device no matter what network I am on.
Please HELP!!!
I have extra equipment if needed (old but the work)... Cisco 3660, Cisco 2600, Cisco 2900XL, Netgear FS518
Thanks in advance...
39 Replies 39
Alright, packet tracer went through, so you think I could ping and connect to the other network.....but I can't...From the ASA CL no ping reply, from Windows no ping reply.....I try to access a device on the other network and no access.
Here is the packet tracer:
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in  id=0xd8e544d0, priority=1, domain=permit, deny=false
        hits=1342, user_data=0x0, cs_id=0x0, l3_type=0x8
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0100.0000.0000
        input_ifc=inside, output_ifc=any
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.2.0     255.255.255.0   inside
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0xd8be0040, priority=3, domain=permit, deny=false
        hits=5, user_data=0x0, cs_id=0x0, flags=0x4000, protocol=0
        src ip/id=0.0.0.0, mask=0.0.0.0, port=0
        dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
        input_ifc=inside, output_ifc=inside
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xd8b3d6c8, priority=0, domain=inspect-ip-options, deny=true
        hits=280, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect icmp
service-policy global_policy global
in  id=0xd8e19810, priority=70, domain=inspect-icmp, deny=false
        hits=5, user_data=0xd88e8248, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 6
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
in  id=0xd8b3d238, priority=66, domain=inspect-icmp-error, deny=false
        hits=5, user_data=0xd8b3d120, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 7
Type: HOST-LIMIT
Subtype:
Result: ALLOW
Config:
in  id=0xd8b23ac0, priority=0, domain=host-limit, deny=false
        hits=161, user_data=0x0, cs_id=0x0, flags=0x0, protocol=0
Phase: 8
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 43028, packet dispatched to next module
Module information for forward flow ...
snp_fp_tracer_drop
snp_fp_inspect_ip_options
snp_fp_inspect_icmp
snp_fp_adjacency
snp_fp_fragment
snp_ifc_stat
Module information for reverse flow ...
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: allow
And the current config:
ASA Version 8.4(1)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network obj_inside
subnet 192.168.1.0 255.255.255.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
nat (inside,inside) dynamic interface
route outside 0.0.0.0 0.0.0.0 68.108.9.1 1
route inside 192.168.2.0 255.255.255.0 192.168.1.5 1
route inside 192.168.3.0 255.255.255.0 192.168.1.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.5-192.168.1.36 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
prompt hostname context
Cryptochecksum:15efd4c561bc04c159b451edef9aa17a
: end
how is the routing configured on the routers? Have you tried pings from routers to hosts. what about a tracert from host to ASA?
Regards.
Alain.
After all this, I think that is the problem...I've looked through every menu on the routers (Belkin n750 & Cisco WRT-310N) and I can find how to add routes or even see the routing table, except for on WRT....but I can't add any routes to it, everytime I try, I get an error. It refuses to take any additional routes.This is the routing table on the WRT.  I can't find the table for the Belkin.
192.168.2.0 255.255.255.0 192.168.2.1
192.168.1.0 255.255.255.0 192.168.1.1
0.0.0.0 .0.0.0.0 192.168.1.1
Do you think this is the problem?
Now indeed it must be the problem as the ASA seems to be fine.
What is the Belkin subnet ? it is the 2.0 subnet so it has a default route pointing to ASA ? if so then it should work between 2.1 and ASA 1.1 .
Try this ping 2.1 from ASA 1.1
Alain.
Still nothing, could I try this?
Belkin = 192.168.3.1  DHCP Scope 192.168.3.5 - 192.168.3.20
WRT-310= 192.168.3.2 DHCP Scope 192.168.3.25 - 192.168.3.45
Keep the subnet kinda the same, just slpit the scope between the two routers?  All I am trying to do, is reduce the load off on router and put it on another.  the WRT-310 has IP Security Cameras that a constantly on and recording, there is one that is wireless and hogging the bandwidth for the rest of my wireless devices.  I want to put those on a different router, but still have access to them from the other computers on the second network.....
I would like to thank you so much for your help, and taking the time to walk me through the process, I learn a lot....thanks agian.
before still making a change I would try to find out why it is not working.
You can ping the ip address of connected router but not the ip address of the subnet just behind?
do a traceroute from ASA to this ip address and also from a host  on the 192.168.2.0/24 subnet do a tracert to 192.168.1.1(the ASA ip address).
post the results here.
Regards.
Alain.
Not sure what happened, but I didn't change a thing and all the sudden I can talk from 192.168.2.1 to 192.168.3.1....but I can't talk to the .2.1 from the .3.1.......
Isn't this a little contradictory?
Surely the arp cache on routers had still old values but I don't know the arp cache timeout on these routers nor if we can clear it manually or even view it.To know the timeout you'd have to sniff from the router to a host an search for arp requests from router and look at the timestamps between the 2 requests.
So what can you do and not do ? It could also be arp on the ASA?  You can do clear arp in privileged mode.
Regards.
Alain.
I found the problem....it's the Belkin Router....I ordered another WRT-310 since that is working well now, just going to copy the same config over when it gets here.  Tracert from the 2.1 network goes through without a problem, but when I do it from the 3.1 side, nothing get through.  No route option is what Belkin told me.
Anyway, once the other router gets here, I think the problem will be solved.  Thanks again for your help.
One last question, my running config will not save.  I do a write mem, but if I reload, nothing is save, it reverts back to default config....any ideas?
verify the config-register value with sh version, it should be 0x1 and try copy run start instead of wr mem.
Let us know.
Regards.
Alain.
