Connecting Three Networks....
woodjl1650
Seems like I spend more and more time in here (Cisco Forums)....
I was talking to a guy today that was trying to help me link my three networks together, so each is sperate but able to talk to each other.  Right now I have them all connect via my ASA, but not able to ping or talk to any of the.  He mention that I could connect them all via a switch and then they should work.
I am new to this world, and having a hard time trying to figure out how to accomplish this.
Right now my network is as follows:
Like I stated before, I want to keep each network seperate, but want to be able to access each device no matter what network I am on.
Please HELP!!!
I have extra equipment if needed (old but the work)... Cisco 3660, Cisco 2600, Cisco 2900XL, Netgear FS518
Thanks in advance...
39 Replies 39
cadet alain
Hi Jonathan,
Do you really think that starting multiple threads about the same subject will help to resolve your problem.
I think that this will have the advert effect because multiple solutions will all get spread across these threads and I think some people may end up tired of seeing you start a new subject as they are already trying to help you for the same problem. post the routes on the routers
Anyway if you want to use the network as it is using the ASA instead of the 3660 to conncet to the cloud it is gonna be more work to configure but it will be more secure indeed.
What model of ASA have you got ? How many interfaces ? What licence? is the Belkin a wireless AP?
Post the config of the ASA and the routes on the routers.
Alain.
ASA 5505 - Basic License  8 ports on the ASA. The Belkin is a a gigabit wireless router, no APs.
Here is the current running config of the ASA...
R1
IP Address = 192.168.1.1
Default Gateway = 192.168.5.1
WAN IP Address = 192.168.5.3
R2
IP Adress 192.168.2.1
WAN IP Adress = 192.168.5.4
R3
IP Adress = 192.168.3.1
WAN IP Adress = 192.168.5.2
Internet IP = 68.108.12.XXX
ASA Version 8.2(3)
hostname ciscoasa
enable password DQucN59Njn0OjpJL encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.5.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
ftp mode passive
same-security-traffic permit intra-interface
access-list 100 extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list 100 extended permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 100 extended permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 100 extended permit ip 192.168.3.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 100 extended permit ip 192.168.2.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 100 extended permit ip 192.168.3.0 255.255.255.0 192.168.2.0 255.255.255.0
pager lines 24
logging enable
logging list IP level informational
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
route inside 192.168.1.0 255.255.255.0 192.168.5.1 1
route inside 192.168.1.0 255.255.255.0 192.168.2.1 1
route inside 192.168.1.0 255.255.255.0 192.168.3.1 1
route inside 192.168.2.0 255.255.255.0 192.168.5.1 1
route inside 192.168.2.0 255.255.255.0 192.168.1.1 1
route inside 192.168.2.0 255.255.255.0 192.168.3.1 1
route inside 192.168.3.0 255.255.255.0 192.168.5.1 1
route inside 192.168.3.0 255.255.255.0 192.168.1.1 1
route inside 192.168.3.0 255.255.255.0 192.168.2.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.5.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.5.5-192.168.5.36 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:66f2eef4d48f50be6c3100c5d6349e7c
: end
ciscoasa(config)#
(sorry for the multiple threads, just trying to find answers and desperate to get this all working)
Thanks for your help.
The Belkin is a a gigabit wireless router, no APs.  if it is wireless then it is an AP.
1) get rid of DHCP server on ASA for routers
no dhcpd address 192.168.5.5-192.168.5.36 inside
no dhcpd enable inside
because i'm not sure your routers are DHCP clients and it is best practice to configure static IP on router, DHCP should be for hosts so you'll configure the pools on each router for the hosts on its segments.
2) concerning static routes on ASA: do this
no route inside 192.168.1.0 255.255.255.0 192.168.5.1 1
no route inside 192.168.1.0 255.255.255.0 192.168.2.1 1
route inside 192.168.1.0 255.255.255.0 192.168.5.3 1
no route inside 192.168.1.0 255.255.255.0 192.168.3.1 1
no route inside 192.168.2.0 255.255.255.0 192.168.5.1 1
route inside 192.168.2.0 255.255.255.0 192.168.5.4 1
no route inside 192.168.2.0 255.255.255.0 192.168.1.1 1
no route inside 192.168.2.0 255.255.255.0 192.168.3.1 1
no route inside 192.168.3.0 255.255.255.0 192.168.5.1 1
route inside 192.168.3.0 255.255.255.0 192.168.5.2 1
no route inside 192.168.3.0 255.255.255.0 192.168.1.1 1
no route inside 192.168.3.0 255.255.255.0 192.168.2.1 1
I've bolded the correct routes.
3) if you want to ping from inside to outside you'll have to permit  ICMP replies on outside interface inbound with an ACL or  inspect icmp which I find more secure.
inspect icmp
4) if you configure same interface traffic then no need for these ACLs which you didn't apply on any interface anyway
no access-list 100 extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
no access-list 100 extended permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
no access-list 100 extended permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
no access-list 100 extended permit ip 192.168.3.0 255.255.255.0 192.168.1.0 255.255.255.0
no access-list 100 extended permit ip 192.168.2.0 255.255.255.0 192.168.3.0 255.255.255.0
no access-list 100 extended permit ip 192.168.3.0 255.255.255.0 192.168.2.0 255.255.255.0
Now for your routers:
on R1 put a default route pointing to 192.168.5.1 and do the same on the other 2 routers.
configure your DHCP scopes
Let us know if pings are working now.
Regards.
Alain.
I loaded that config, but now I lost the internet connection to the routers...  Also on the Cisco M10 Router, I tired to set the default route but was unable:
Destination IP - 192.168.5.1
Subnet - 255.255.255.0
Gateway - ???  I tried the 192.168.5.1, but it said it couldn't be the same as the IP Address
DHCP is enabled on each router, as before and in the diagram.
ASA show ip
System IP Addresses:
Interface                Name                   IP address      Subnet mask     Method
Vlan1                    inside                 192.168.5.1     255.255.255.0   CONFIG
Vlan2                    outside                68.108.12.252   255.255.255.0   DHCP
Current IP Addresses:
ASA running config
ASA Version 8.2(3)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
nat-control
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
Cryptochecksum:057b2b766126b5aedae8bc23152ba705
From the ISP:
Subnet Mask
255.255.255.0
Wan IP
68.108.9.226
Default Gateway
68.108.9.1
DNS Address
68.105.28.12
Condition
Connected
WAN IP different than what the ASA says because I have to us a backup router to get back on the internet, so new IP since it is dynamic.
the destination IP for a default route is 0.0.0.0 and mask is 0.0.0.0
You left DHCP scope on the ASA !
What does the show route on ASA says. Can you ping the routers IP in 5.0 network from the ASA?
Can you ping the subnets 1.0-2.0-3.0 from the ASA ? and vice-versa?
Regards.
Alain.
Oooppss....I thought I took DHCPD out...it's gone now....
Here is the show route:
ciscoasa# show route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is not set
C    192.168.5.0 255.255.255.0 is directly connected, inside
S    192.168.1.0 255.255.255.0 [1/0] via 192.168.5.3, inside
S    192.168.2.0 255.255.255.0 [1/0] via 192.168.5.4, inside
S    192.168.3.0 255.255.255.0 [1/0] via 192.168.5.2, inside
ciscoasa#
And not able to ping between the three....
For this:
"Now for your routers:
configure your DHCP scopes"
I need to go into the router setup and do this corrent?  That is what I tried to do and got this:
"Destination IP - 192.168.5.1
Gateway - ???  I tried the 192.168.5.1, but it said it couldn't be the same as the IP Addre"
as I said above a default route is address = 0.0.0.0 and mask = 0.0.0.0
do this on each router ans also don't forget hosts must have their default gateway as IP address of router in their subnet.
You have no default route from your ISP so you won't get to the internet for sure.
adde this on the ASA: route outside 0.0.0.0  0.0.0.0   68.108.9.1
Regards.
Alain.
Here is what on one of my routers, no internet access....
Router 3
Router IP - 192.168.3.1
WAN PORT - Static IP
Internet IP  Address:     192.168.5.2
Subnet Mask:            255.255.255.0
Default Gateway:     192.168.5.1
DNS 1:                     8.8.8.8
DNS 2 (Optional):     8.8.4.4
DNS 3 (Optional):
The routing table - I haven't changed anything here....
Destination LAN IP          Subnet Mask            Gateway    Interface
192.168.5.0                 255.255.255.0               192.168.5.5         Internet (WAN)
192.168.3.0                 255.255.255.0               192.168.3.1         LAN & Wireless
0.0.0.0                            0.0.0.0                     192.168.5.1         Internet (WAN)
the default route is ok:
But as our IP is 192.168.5.5 so on the ASA the route must be like this:
route inside 192.168.3.0 255.255.255.0 192.168.5.5
Verify your routers IP in the 5.0 network and change the routes accordingly on the ASA and don't forget the default to the ISP gateway as you didn't receive it via DHCP as it seems.
Regards.
Alain.
Finally got the internet, had a bad route.  From the ASA I am not able to ping the router nor can I see any other network devices on the 192.168.2.0 or the .3.0 networkl
Here is the running config:
ASA Version 8.2(3)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Vlan3
no nameif
no security-level
no ip address
ftp mode passive
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
nat-control
route outside 0.0.0.0 255.255.255.0 0.0.0.0 1
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
Cryptochecksum:54d46a5e9207aac89651df334cde9b1d
: end
route outside 0.0.0.0 255.255.255.0 0.0.0.0 1  not good  should be route outside 0.0.0.0 0.0.0.0
Verify those IP addresses are correct ones on each router
then verify your default routes on the router all point to the ASA 192.168.5.1 ip address
verify your hosts have default gateway as ip address of router in same subnet( for 3.0 it should be 3.1 and so on)
then ping router adressses in 5.0 from ASA, if it works then ping 1.1,2.1,3.1 from ASA, if it works ping from hosts to ASA 5.1
If non works then post results and then do traceroute and post results
Regards.
Alain.
I've gone through every menu on the Belkin Router and I can't seem to find the routing table to make sure that the router is routing to the ASA.  The only way I can get internet to the Belking is making a static WAN port with the address 192.168.5.3 default gateway of 192.168.5.1.  I believe this is were my problem is.....But even from the ASA I still can not ping the routers..... Any Idea?
yes doing it this way on the router should be ok for default route.
So on ASA you ping 192.168.5.3 and the pings timeout?
post sh route and sh arp on ASA after the ping fails then do this command:
packet-tracer input inside icmp 192.168.5.1 192.168.5.3  detailed
post result
Alain.
