Connecting Three Networks....
woodjl1650
Seems like I spend more and more time in here (Cisco Forums)....
I was talking to a guy today that was trying to help me link my three networks together, so each is sperate but able to talk to each other.  Right now I have them all connect via my ASA, but not able to ping or talk to any of the.  He mention that I could connect them all via a switch and then they should work.
I am new to this world, and having a hard time trying to figure out how to accomplish this.
Right now my network is as follows:
Like I stated before, I want to keep each network seperate, but want to be able to access each device no matter what network I am on.
Please HELP!!!
I have extra equipment if needed (old but the work)... Cisco 3660, Cisco 2600, Cisco 2900XL, Netgear FS518
Thanks in advance...
39 Replies 39
ciscoasa# show route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 68.108.12.1 to network 0.0.0.0
C    68.108.12.0 255.255.255.0 is directly connected, outside
C    192.168.5.0 255.255.255.0 is directly connected, inside
S    192.168.1.0 255.255.255.0 [1/0] via 192.168.5.3, inside
S    192.168.2.0 255.255.255.0 [1/0] via 192.168.5.4, inside
S    192.168.3.0 255.255.255.0 [1/0] via 192.168.5.2, inside
S    0.0.0.0 255.255.255.0 [1/0] via 0.0.0.0, outside
d*   0.0.0.0 0.0.0.0 [1/0] via 68.108.12.1, outside
                     [1/0] via 68.108.9.1, outside
ciscoasa# sh arp
        inside 192.168.5.3 0886.3b20.29b1 56
        inside 192.168.5.2 687f.7442.dc30 140
        outside 68.108.9.1 0030.b8c1.2910 0
        outside 68.108.12.1 0030.b8c1.2910 8
ciscoasa# ping 192.168.1.1
Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
ciscoasa# ping 192.168.5.3
Sending 5, 100-byte ICMP Echos to 192.168.5.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
So I can ping 192.168.5.3 from the ASA, but I can ping the routers them selves...192.168.1.1, 192.168.3.1...nor can I access files and shares between the three networks.
you received your default route from DHCP so you can delete the static default you configured.
if the pings don't work then traceroute and do the packet-tracer command I posted above.
Did you verify on the routers that the  5.0 addresses are correct and which one has the 1.0-2.0 and 3.0 because then you'll have to modify your static routes on the ASA.
Alain.
For some reason I can't get the packet-tracer to work on the CL, but on and ADSM, it is dropped due to config implicit rule
hi,
Can you ping 3.1 from 2.1 ? what is a packet-tracer telling you for this?
Can you try with no nat-control
Alain.
NAT dropped it:
dynamic translation to pool 1 (no matching global)
ciscoasa# packet-tracer input inside icmp 192.168.1.1 22 22 192.168.3.1 detail$
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   192.168.3.0     255.255.255.0   inside
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Forward Flow based lookup yields rule:
in  id=0xd7da7018, priority=3, domain=permit, deny=false
        hits=94, user_data=0x0, cs_id=0x0, flags=0x4000, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0xd7da8688, priority=0, domain=inspect-ip-options, deny=true
        hits=3580, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect icmp
service-policy global_policy global
in  id=0xd83dfff0, priority=70, domain=inspect-icmp, deny=false
        hits=28, user_data=0xd83dfe98, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 5
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
in  id=0xd7da8300, priority=66, domain=inspect-icmp-error, deny=false
        hits=219, user_data=0xd7da81e8, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 6
Type: NAT
Subtype:
Result: DROP
Config:
nat (inside) 1 0.0.0.0 0.0.0.0
  match ip inside any inside any
    dynamic translation to pool 1 (No matching global)
    translate_hits = 95, untranslate_hits = 0
in  id=0xd53930d8, priority=1, domain=nat, deny=false
        hits=125, user_data=0xd5393018, cs_id=0x0, flags=0x0, protocol=0
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Have you tried disabling nat-control with no nat-control before doing the packet-tracer?
if so then reenable it and try again
Regards.
Alain.
No luck at all.....I have redone my setup to use only two routers.
Internet--->ASA (192.168.1.1) ---->Belkin n750 (192.168.3.1) ----> internal devices
                                                ---->WRT-310N (192.168.2.1) --->internal devices
Like before my goal is to get both networks talking to each other.
Here is the running config as of right now:
ASA Version 8.4(1)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
prompt hostname context
Cryptochecksum:e5b1dd8953c2a0ad36aec4a546a47d18
: end
I hink changing the device or topology and here the ASA OS version everytime you get into trouble and the solution is not given fast enough won't help you comprehend things and will make our task more complicated but it's your network anyway but I just wanted to give my point of view about the way you apprehend stuffs.
Now you changed ASA version, why that? the NAT operations are completely different from previous versions, I don't think the version had anything to do with your problem.
You also changed the topology, it would be great to post your new topology diagram it will be simpler to troubleshoot your configuration.
But I noticed you have no route anymore in this config.
Regards.
Alain.
I removed the thrid router because it was extra and not needed.  The ASA software update, I thought might help.  Error on my end I guess.
Here is my update diagram.....like before, just want to be able to communicate between the two networks.  Right now the internet is work on both, just need to be able to access one from another.
Thanks for the help, and I promise no more changes unless directed to.......
the IP addresses on your diagram do not correspond to your config, in config inside is 1.0 but in diagram there is no such network.
You will also get the same problem which is same-security traffic which wasn't working.
I found interesting info from Cisco configuration guide and it seems you have to nat traffic for same security interface.
Here is the part:
NAT and Same Security Level Interfaces
NAT is not required between same security level interfaces even if you  enable NAT control. You can optionally configure NAT if desired.  However, if you configure dynamic NAT when NAT control is enabled, then  NAT is required. See Chapter 27 "Configuring NAT Control," for more information. Also, when you specify a group of IP addresses  for dynamic NAT or PAT on a same security interface, then you must  perform NAT on that group of addresses when they access any lower or  same security level interface (even when NAT control is not enabled). Traffic identified for static NAT is not affected.
This was surely your problem and it will still be in this topology.I thought no nat-control would have solved the problem but Cisco says it is not.
So with older OS version you would have to do this:
global (outside) 1 interface
global (inside) 1 interface
As I'm not used to newer syntax I can't tell you how to do it for sure but I think this should do it:
nat (inside,inside) dynamic interface
Don't forget to add your routes for the subnets on the ASA as there are none in your config.
Regards.
Alain.
When I apply that I loose my connection to the internet.  Also what routes should I have?
ASA = 192.168.1.1
Router 1 = 192.168.3.1
Router 2 = 192.168.2.1
ok so it is replacing the other nat statement I'm gonna look at the ASA config guide for NAT on 8.4 and tell you but it would have been simpler to leave the old version.
concerning routes: see my previous posts and adapt,in short you must have a route for every subnet not connected that points to the next-hop( ip address in the same subnet as ASA of the router which owns the subnet)
Regards.
Alain.
Applied the routes, at least I think I did them right...
Router 1 = 192.168.3.1 connecto ted ASA port0/1 -----> ASA IP 192.168.1.2
Router 2= 192.168.2.1 connected to ASA port0/2-----> ASA IP 192.168.1.5
ASA = 192.168.1.1
ISP Default Gateway = 68.108.9.1
This is the route I applied:
route outside 0.0.0.0 0.0.0.0 68.108.9.1 1
route inside 192.168.2.0 255.255.255.0 192.168.1.5 1
Here is the show route:
C    192.168.1.0 255.255.255.0 is directly connected, inside
S    192.168.2.0 255.255.255.0 [1/0] via 192.168.1.5, inside
Current Config:
ASA Version 8.4(1)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
pager lines 24
mtu outside 1500
mtu inside 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
Cryptochecksum:71d6ba76d5c5c74a6ad9b7403b8258ff
: end
you forgot the route for 3.0: route inside 192.168.3.0 255.255.255.0  192.168.1.2
You already have a default route advertised by dhcp from ISP:
So here you're gonna do load balancing. I would remove the static route you configured
for the nat on same-security interface: try this
same-security-traffic permit intra-interface
object network obj_inside
subnet 192.168.1.0 255.255.255.0
nat(inside,inside) dynamic interface
Regards.
Alain.
