Connecting to switch w/o Serial Cable
maxreality
Hello All,
I have a Catalyst 2940 and I don't have a serial connection on my laptop. Is there a way to connect using rj-45 to rj-45 or will I need to find a computer with a serial port?
Pravin Phadte
Level 5
Level 5
you can have cable converter using usb.
You can get it on ebay and yes you wil require drivers :)
http://www.digitalhoop.com/cisco-compatible-console-cable-usb-kit-p31352.html
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150333556637
Hope this helps
pravin
Pravin Phadte
Level 5
Level 5
Hope this helps
pravin
