Issue with a Cisco 837
elias.manchon
Hello Folks!!
I have a problem with a cisco 837. When I connect the device to ADSL line, the CD led is off, the TX and RX leds are blinking. On the ADSL line exist other router that I want to replace with it and this other work fine.
Could somebody help me please?
Thanks in advance!!.
No, it would not.
7 Replies 7
paolo bevilacqua
Post "show dsl interface".
Hi p.bevilacqua
I cannot run "show dsl interface" on the router, because it's in the other business. But I have to say you that I suspect that DSL line is a ITU G.992.5 and I think that this router model not support this line type. This reason is sufficient for the cd led is switch off?.
Thanks in advance.
If should synchronize nevertheless at a lower speed. There is newer firmware that you can try.
Where is the firmware?. I had understood that this model not supported ADSL2+. Then I'm wrong about this question?.
Thanks.
Check:
http://www.cisco.com/en/US/prod/collateral/routers/ps221/prod_bulletin0900aecd801d5c4c.html
However an adsl2 router would be the best choice.
Please remember to rate useful posts with the scrollbox below.
You want to me that I update my firmware with the last versión, it would support ADSL2+?.
No, it would not.
