Connecting two subnets
dataIP
I have a problem with linking two seperate subnets which contain a individual small business networks.
Setup is each network has an ASA5505 and a 887 to provide internet connectivity. A variety of Cisco small business and one enterprise switch provide the switching. Each network contains its own servers and clients.
As a temporary measure I need to be able to access resources 'cross subnets'. (It is one business that has split in to two business units, so no privacy/security issues). The router will be removed once all relevant data has been migrated between networks.
Networks are 192.168.88.0 and 192.168.0.0, both with netmasks of 255.255.255.0
So, as a simple example a server on the .88 network needs to access information on a server at 192.168.0.128
We have the two segments linked with a Cisco E1000 router (was using a 871, but that seemed to cause more issues). IPs are 88.253 and 0.253 on each side.
I have enabled RIP on the E1000 and both ASA.
Both ASA have same-security-traffic permit intra-interface
From the 88.128 server, I can ping everything on the .88 network plus the far side of the E1000 (at 0.253) and the far side ASA (at 0.254), but not the far side server (at 0.128).
Maybe going back to the 871 may be a good plan, at least I should be able to debug things a bit easier from the command line?
I am sure there is something fundamental I am missing here.
48 Replies 48
I Just Checked I Hope E1000 Will not Support L3 VLAN's it will only have the only one WAN Port and 3 or 4 Fa ports which will be used for extending Created LAN Subnet. please refer
http://www.winotek.com/multimedia/items/E1000_V10_UG_USA_NC-WEB,0.PDF
E1000 *should be* doing ip routing...
I think it must be okay as some addresses on the B network can be accessed.
On network A, no VLANs are in use.
Network B has a voice VLAN and a default VLAN... we are only interested in the default data VLAN.
I think I will simplify tomorrow... I will use a real switch (probably an HP one) instead of the built in on on the 'LAN side' of the E1000. I will also replace that with a 871 suitable setup.
Maybe we will get somewhere then.
Thanks to all, for your help so far.
Netmask on both servers is correct 255.255.255.0
Both servers have the correct ASA as their default gateway... ie. ServerA has ASA at 192.168.88.254
ServerB has ASA at 192.168.0.254
From earlier post i though you had the default gateway as E1000 and not ASA
Najaf
The default gateway for all devices on networkA (88.0) is the ASA at 88.254
The default gateway for all devices on networkB (0.0) is the ASA at 0.254
The ASA hopefully learns its route via RIP.
As it happens I did earlier try a static route on the ASA for the other network (via the router at x.253)... but that didn't work for me either.
dataIP
Okay, new day, new setup... similar problem!
I have been in and changed the E1000 router for a proper 871
An HP switch has been added in the A network just so the fa0-fa3 ports are not being used as switch ports.
871 now links NetworkA (88.0) via fa0 with IP 192.168.88.253 and NetworkB (0.0) via fa4 with IP 192.168.0.253
Default gateway for each network is its onw ASA at x.254
This has to be the simplest setup!
RIP is enabled on the 871
I am getting less conectivity today.... looks like the 871 isn't routing.
show ip route gives me
Gateway of last resort not set
C   192.168.88.0/24 is directly connected,Vlan1
C   192.168.0.0/24 is directly connected, FastEthernet4
I don't see any RIP entries.
ip routing has been entered at the command line (with no errors)... but I don't see this in the running config!
I have cdp running, and that does see the cisco switch on the B network so I am certain the physical connections are as they should be.
Any more clues... and thanks for everyone's interest.
Mark
Try to add static route on the server 0.128
route add 192.168.88.0 mask 255.255.255.0 192.168.0.253
Hope it will help.
Best regards,
Abzal
If you are running sh ip route command in 871 router , That is the correct output it will show connected routes only.
Could update the current topolgy diagram.
Is ASA1,ASA2,and 871 are part RIP right. ?
if it is the Case you
Will update the drawing in a moment.
ASA1, ASA2 and 871 all have RIP enabled.
router rip
version 2
network 192.168.0.0
network 192.168.88.0
no auto-summary
Diagram updated... has to be the simplest configuration for a router.
what is the sh ip route output on ASA1 and ASA2
On ASA 1 we see
Result of the command: "sho route"
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is xxxxxxrouter ipxxxx to network 0.0.0.0
C    192.168.88.0 255.255.255.0 is directly connected, inside
C    xxxxxxour outside ipxxxx 255.255.255.252 is directly connected, outside
R    192.168.0.0 255.255.255.0 [120/1] via 192.168.88.253, 0:00:06, inside
S*   0.0.0.0 0.0.0.0 [2/0] via xxxour outside router ipxxxxx, outside
Which looks right to me, RIP route to the other network via the 871
On ASA2 we see
Gateway of last resort is 194.xx.xx.xx to network 0.0.0.0
R    192.168.88.0 255.255.255.0 [120/1] via 192.168.0.253, 0:00:05, inside
C    network.outside 255.255.255.248 is directly connected, outside
C    192.168.0.0 255.255.255.0 is directly connected, inside
S*   0.0.0.0 0.0.0.0 [2/0] via 194.xx.xx.xx, outside
Which again looks right to me.
Main point of my confusion now is why the 871 doesn't seem to show any routes leaned by RIP... in fact to me it looks like it is refusing to route anything.
The reason 871 is not showiny any RIP route is due to the fact that it has both network as directly connected.ie 192.168.88.0/24 and 192.168..0.0/24.
Directly connected networks always shows as connected and not through routing protocol (RIP in your case)
Also after changing from E1000 to 871 what is the reachabilty status between devices in both network. Is it same like what you had before?
Najaf
Okay, I now understand the output of the sho ip route on the 871.
Next part of investigation is;
from network A (88.0) I can ping 192.168.88.253 (network A side of the 871)
but can NOT ping 192.168.0.253 (network B side of 871)
That surely means the problem is within the 871... again it looks like it isn't routing anything at all.
Posting config below;
Current configuration : 2125 bytes
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname router1
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret 5 $1$6Dat$gYL95JVQCJoAuVFcVbr.w0
username root privilege 15 secret 5 $1$7Lum$WaC.KWbxa.n/y7uhbOtI11
clock timezone PCTime 0
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip bootp server
no ip domain lookup
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
ip address 192.168.0.253 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.88.253 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
ip tcp adjust-mss 1452
router rip
version 2
network 192.168.0.0
no auto-summary
ip classless
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
logging trap debugging
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport preferred all
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output all
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
I think you have a problem here. Try modifying the configuration as below.
interface Vlan1
no ip address
interface FastEthernet3   ---------------------> Connect this port to HP Switch
interface FastEthernet4 ---------------------> Connect this port to B side Switch
ip route 192.168.0.0 255.255.255.0 192.168.0.254
ip route 192.168.88.0 255.255.255.0 192.168.88.254
NOTE:- Personally i have not worked on 871. But im assuming that we can set individual ip address of both FasEhternet interface of 871.
If router does not accept ip address on both fastEthernet please modify configuration as below
interface Vlan1
As i understand it by default FasEthernet 3 would be under vlan 1.
First check from router you are able to reach Side A and Side B networks
Then check if Server A can reach till up to 192.168.0.254 and rest of the network
Najaf
