05-19-2021 06:41 AM
Hello.
Can somebody help me please. I have remote management by ssh to a router (2921), but I continually get this message and I cannot make configurations because it disconnects every 1 second:
"Connection was reset"
I deleted this command: ip ssh time-out 60. But the problem was not solved.
05-19-2021 09:06 AM
Do you have stable connection to connect to Router, is this in same network or remote ?
what you see Logs in the Router ? can you post show version ?
suggest to zerokey and configure again SSH config and test.
05-19-2021 12:45 PM
Can you post the current running config? This might be something about the setup for SSH, could be something about the setup of vty, could be something else?
