connections refused for webpage with address of ip:portal by ISR 4431
txu
I have a router (Cisco 4431) that manages a few servers within a client's network: the router gets an IP (172.24.62.135) within client's network that I can access and each of the servers gets a portal with nat translation as shown below
ip nat inside source static tcp 192.168.2.10 22 172.24.62.135 2210 extendable (Portal22 translation)
ip nat inside source static tcp 192.168.2.10 8080 172.24.62.135 9080 extendable (Portal8080 translation)
192.168.2.10 is one of the servers
Also with the Portal22 translation, I can ssh into 192.168.2.10 portal 22 like this
ssh -p 2210 username@172.24.62.135
Meanwhile 192.168.2.10 host a webpage via :8080 portal. If there was no router, the normal web address looks like
192.168.2.10:8080/admin
with Portal8080 translation above, the web address changes to
172.24.62.135:9080/admin
This used to work a few months ago (something might have been changed since then, but I don't know what/when). Now, 172.24.62.135:9080/admin gets errors like
This site can't be reached, 172..24.62.135 refused to connect.
I wonder if you could please help on what went wrong and how to fix it. Most likely the problem is from router, as another server 192.168.2.25 which is very similar to the 192.168.2.10 server, and both .25 and .10 cannot show :9080/admin page.
THANK YOU FOR YOUR INPUT!
The current settings of the router is pasted below (with private info strings changed):
ROUTER#wr term
Building configuration...
Current configuration : 7287 bytes
! Last configuration change at 15:55:17 UTC Wed Aug 14 2019 by admin
version 15.5
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname XXXXXX-YYYY-ROUTER
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging buffered informational
no logging console
enable secret 5 $1$Tzun$Dxxxxxxxxxxxxxxx
no aaa new-model
ip name-server 129.176.100.5 129.176.171.5
ip domain name yyyyclinic.org
ip dhcp excluded-address 192.168.2.1 192.168.2.200
ip dhcp pool YYYY-CLINIC
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 129.176.199.5 127.0.0.1
domain-name yyyyclinic.org
subscriber templating
license udi pid ISR4431/K9 sn FOC21482HQ1
username admin privilege 15 password 7 14xxxxxxxxxxxxxxxxxxx7B
username username privilege 15 password 7 14xxxxxxxxxxxxxxxxxxx7B
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
description CONNECTION TO Cisco SG200 SW gig 0/0/0
ip address 172.24.62.135 255.255.254.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
description LAN ISOLATED NETWORK
ip address 192.168.2.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
negotiation auto
interface GigabitEthernet0/0/2
no ip address
negotiation auto
interface GigabitEthernet0/0/3
no ip address
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip nat inside source static tcp 192.168.2.11 22 172.24.62.135 2211 extendable
ip nat inside source static tcp 192.168.2.12 22 172.24.62.135 2212 extendable
(many lines of nat translation entries)
ip nat inside source static tcp 192.168.2.19 443 172.24.62.135 4439 extendable
ip nat inside source static tcp 192.168.2.25 8080 172.24.62.135 8025 extendable
ip nat inside source list XXXXXX-OUTBOUND interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 172.24.62.1
ip ssh time-out 60
ip ssh authentication-retries 5
ip access-list extended XXXXXX-OUTBOUND
permit ip 192.168.2.0 0.0.0.255 any
control-plane
banner exec ^CCC***CAUTION:  You are connected to XXXXXX-YYYY-ROUTER ***^C
banner login ^CCC
Warning: This system is for authorized use only.  Any use of this system without
or in excess of approved authority is subject to prosecution.  All activities on
this system are monitored, recorded and reviewed.  Anyone using this system
is advised that if such monitoring reveals possible evidence of criminal
activity, this information may be provided to law enforcement or other
authorized agencies.
^C
line con 0
exec-timeout 60 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
exec-timeout 60 0
password 7 10580xxxxxxxxxxxxxxxxx7
login local
transport input telnet ssh
end
txu
Forgot to mention, one more nat translation
ip nat inside source static tcp 192.168.2.10 80 172.24.62.135 8080 extendable (Portal80 translation)
with the Portal80 translation, the webpage of
192.168.2.10:80/stats
translated into
172.24.62.135:8080/stats
which shows the page well
This indicates 192.168.2.10 server can show :80 page, but not :8080 page.
