do i have to create a static route for multiple routers to get to a network ?
dolanduck.
For example say i have 3 routers connected to each other and on the left i have 192.168.0.0 which is connected to R1 and i want to reach 192.168.9.0 network  which is connected to r3. My question is do i have to create a static route for each router to get to the other network or do i create one static route on the router 192.168.0.0 is connected to ?
luis_cordova
Hi @dolanduck.  ,
If you are going to route by static routes, you must create a static route or routes to get to mark the path that the packet must take to go and return:
192.168.0.0/24 f0/0 R1 f0/1 192.168.1.0/24 f0/0 R2 f0/1 192.168.2.0/24 f0/0 R3 f0/1 192.168.9.0/24
R1
ip route 192.168.9.0 255.255.255.0 f0/0
R2
ip route 192.168.9.0 255.255.255.0 f0/1
ip route 192.168.0.0 255.255.255.0 f0/0
R3
