Console via aux port on Cisco891F Router
danielmaisu
I am trying to console to another router connected via a aux port. Following is my setup
R1(aux port)------------>R2(console port)
On R1
following is the aux port configs
line aux 0
 modem InOut
 no exec
 transport preferred telnet
 transport input all
 transport output all
interface Loopback1
ip address 1.1.1.1 255.255.255.255
sho line output
 Tty Typ     Tx/Rx    A Modem  Roty AccO AccI   Uses   Noise  Overruns   Int
      0 CTY              -    -      -    -    -      0      30     0/1554    -
*     1 AUX      0/0     - inout     -    -    -      1       0     0/0       -
      3 TTY              - inout     -    -    -      0       0     0/0       -
i try to telnet into R2 on loopback1 address port 2001
Following is the result
R1#telnet 1.1.1.1 2001
Trying 1.1.1.1, 2001 ...
% Connection refused by remote host
Please check to see if i have missed anything.
i also note that the console port is also the aux port on Cisco891F
assuming that the physical connection works (a rollover cable, or the blue cable that comes with the routers), make sure that the console port is configured with the 'exec' command.
Can you post the configuration you have for the console port ?
