Consolidating ACLs on 3845 with IOS 12.4(3d)
mvsheik123
Level 7
Level 7
Hi All,
We have a 3845 perimeter router with IOS 12.4(3d). Our users FTP to certain destinations for to get some data. As each and every destination IP hits the same port(s), Instead of adding same commands for each IP, Iam looking for a way to consolidate the ACL (ex: object group). Looks like 12.4(3d) does not support this feature. Any suggestions..?
Thank you in advance
MS
No, it does not help. IOS does not support.
If you upgrade the IOS to 12.4(20)T, you can then use object-groups. You asked for suggestions, that is one.
Thank you for the suggestion.
MS
