Prob DHCP: address allocation on ADSL interface C837
tarik.fakir
Hello all,
I've started for first time configuration of my new ADSL router (Cisco 837)
The issue is the router coudn't get an IP adress from DHCP server of me ISP
You can see attached :
- sh ver
- sh ip int br
- sh run
& sh dhcp server: witch show no requests go out!!
Any advices
Hi tarik,
Under you ATM interface, explicity specify the encap and protocol using
interface ATM0
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
After configuring this (issue shutdown and no shutdown to restart the interface)
Lejoe
lejoe.thomas
Level 3
Level 3
Hi Tarik,
Under dialer interface
remove ip address dhcp
and add
int dialer 0
ip address negotiated
this allows for the IP address of the dialer interface to be obtained via PPP/IPCP address negotiation
Lejoe
Hello Lejoe,
I've done it but same result: no ip @ even interfaces up (atm 0 & dialer 0)!!
So need help again
# Sorry for delay I was away ;-)
Hi tarik,
interface ATM0
pvc 0/38
Lejoe
