Showing results forĀ
Search instead forĀ
Did you mean:Ā
control routes on mpls router
vishal.rane
need assistance on how to control the routes for sending and receiving on a mpls router at HQ
MPLS cloud is running  BGP
on LAN we run OSPF
HQ routes need to be seen by remote office behind mpls
172.16.20.1/23
10.10.1.0/24
192.168.1.0/24
Remote office routes needs to be seen by HQ
192.168.100.0/24
192.168.105.0/24
192.168.110.0/26
current config for ospf and bgp
router ospf 2
redistribute bgp 2154 subnets
network 172.16.1.1 0.0.0.3 area 0
router bgp 2154
no sync
redistribute ospf 1 match internal external 1 external 2
neighbor 172.31.66.253 remote-as 2100
Vishal
Lei Tian
Are you not seeing the routes in remote or HR? You should be able to see the routes with the redistribution. However, there will be potential routing loop with mutual redistribution. Few methods you can consider to avoid routing loop
1, do not use mutual redistribution, use network statement under bgp to advertise local routes instead.
2, use tag to filter routes
3, use prefix-list to limit ospf/bgp only redistribute local routes.
HTH,
Lei Tian
Lei
can you help with an example to follow
INE has a pretty good VOD on route redistribution, which you can find from
http://blog.ine.com/tag/route-redistribution/
There is also document on CCO that has example on using tag to prevent routing loop
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009487e.shtml
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008047915d.shtml
HTH,
Lei Tian
