Converting external CSU to internal CSU
thomuff
Level 3
Level 3
I have T1 connection. 17 channels for data. The remaining 7 for voice. I have a Paradyne external CSU at each end. What kind of Cisco internal module could I use to replace these Paradyne CSUs and do have example of the configuration. I am pretty sure I would use a VWIC-2MFT-T1-DI but I can't figure out how I configure the voice to go out the second interface connecting the PBX.
aghaznavi
Level 5
Level 5
check out if the following link on Understanding Support for Voice and Data on 2600/3600 Series Routers helps :
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a0080100688.shtml
mmorris11
Level 4
Level 4
Use the 2nd generation card VWIC2-2MFT-T1/E1 for total flexability. The doc you need to configure this card is in the relevant IOS guide.
Although not as exhaustive, one helpful page for config is:
http://www.cisco.com/en/US/customer/products/hw/modules/ps2617/products_configuration_example09186a008052c920.shtml
More info:
http://www.cisco.com/en/US/customer/products/ps5855/products_qanda_item0900aecd8028d2e5.shtml
HTH pls rate!
