copy image from tftp to ASA flash;
itdsmartnet
hi,
i have 5550 ASA with ios version 7.1(2), i have downloaded newer version "asa804-k8" when i copy my image to ASA flash the following error occured "%Error reading tftp://192.168.1.2/asa804-k8 (File not found" what might be the problem
Danilo Dy
1. Make sure your tftp application is pointing to the drive/directory where the image is located.
2. Include .bin as in asa804-k8.bin
hi,
Thanks for your reply , i forgot to add .bin.
regards
Hi Waseem,
Are you able to upload the image now?
You forgot to mention whether your problem has been resolved or you forgot the ".bin" in your post here or when you are uploading the image.
Dandy
