Copy Layer2 Mac Address Table to remote FTP server
hi all,
It is required to import all the mac address table entries in my branch switches to the remote FTP Server. Futher I should also mention my LAN interface as a source interface, because I dont have routes to my WAN Interface from the Head Office.
Corressponding table (attached) should be copied to the remote ftp server periodically.How can I enable this config and what are the configurations I should do ?
Edison Ortiz
You can automate this process with any NMS (Network Management System) - like CiscoWorks.
Much simpler and less painful than configuring scription on a switch.
Depending on the IOS version you are running many of the scripting features aren't avaliable or have multiple caveats.
Best to rely on what's proven to work, using NMS tools.
