Core switches for DR site and DC site
lovejit1313
Hello Guys,
I am looking for a suggestion for 24 Ports 10 GB switch as a Core switch. We are a small manufacturing company not hosting anything else than web servers. Everything else local servers.
2 Accepted Solutions
Hello
You don’t state if you have any on-site IT staff or not but if your looking for a L3 switch with 10gb port capacity and to easy manage ,scalable and not as expensive as the new cat9ks suggest possibly look at the meraki cloud switch’s
https://meraki.cisco.com/products/switches/ms425-16
Kind Regards
Paul
the C9300-24UX would be an option, it has 24 modular Multigigabit Cisco UPOE (100M, 1G, 2.5G, 5G, or 10 Gbps) ports. Have a look at the datasheet for the Catalyst 9300 series below:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
9 Replies 9
Hello
Kind Regards
Paul
Hello @paul driver
We are looking for a fully Manageable switch which can also be utilized as PE in the MPLS scenario.
Martin L
I work with 3850s which have large variety of selection. mostly for distribution and access layers but check product site for core level.
otherwise, I agree with posts above regarding Catalyst 9300
Leo Laohoo
Copper or fibre?
Hello @Leo Laohoo  @Georg Pauwen  @paul driver  @Martin L  ,
It will be copper, the regular ethernet connections.  I don't see any 24 port switch with all 10 GB ports. please suggest?
I hope you already purchased the Switch.
For future reference you can use below URL in order to know which you need to purchase.
https://www.cisco.com/c/en/us/products/switches/switch-selector.html
24-ports 10GBASE-Tx?
You're looking at a Nexus 5K with a 2K FEX.
Hello @Leo Laohoo  ,
I am looking for both copper as well as fiber.
