CP Experess
diek
                   I have a new 1921 router and when I try to use CP Express I get a Microsoft Internet Explorer error.
Cisco CP Express Application could not be launced. If CP Epress is launched using https try the following steps and relaunch CP Express.
1. Disable TLS option in JRE Settings[Java Control Panel->Advanced ->Security]
I have done this and still get the same error. I initially used the console port and assigned a user name and password per the warning message.
I normally use command line entries to setup my routers but this is first new router I have gotten in some time and am not familliar with the CP Express and thougt I would try it. Is there a way to load a default program that does not have all the CP Express data in it without manually removing it?
diek
I replaced IE6 with IE8 to fix the problem. Still like the command line config better and don't like all the extra note information in the config dislpay from the console port or telent entry.
