How to remove a file with SNMP from router
guidobrinkmannl
On a 3945 voicegateway,
I want to remove a wave file (announcement), with the purpose that a new one can be automaticaly downloaden from UCCE to the box.
Is there a way to do that automaticaly with SNMPSET <voicegateway> <MIB OID> <??wave file name??> <reload>
thanks,
EDIT: or clear the cache, which it should be I think. (all wave file cache, or only one file, not sure what should be used and/or what is possible
Dan Frey
Take a look at the CISCO-FLASH-MIB to copy and delete files with snmp.
To delete a file called "isakmp_staticroute_eem.tcl" on flash:
#ciscoFlashMiscOP branch to call out file to delete, createAndGo
[dafrey@HammerHead  TC$ snmpset -v 2c -c private 192.168.0.1  ciscoFlashMiscOpCommand.101 i  3 \ ciscoFlashMiscOpDestinationName.101 s isakmp_staticroute_eem.tcl \
ciscoFlashMiscOpEntryStatus.101  i 4
CISCO-FLASH-MIB::ciscoFlashMiscOpCommand.101 = INTEGER: delete(3)
CISCO-FLASH-MIB::ciscoFlashMiscOpDestinationName.101 = STRING: isakmp_staticroute_eem.tcl
CISCO-FLASH-MIB::ciscoFlashMiscOpEntryStatus.101 = INTEGER: createAndGo(4)
#Verify file is removed
[dafrey@HammerHead TCL]$ snmpwalk -v 2c -c private 192.168.0.1 ciscoFlashMiscOpTable
CISCO-FLASH-MIB::ciscoFlashMiscOpStatus.101 = INTEGER: miscOpOperationSuccess(2)
CISCO-FLASH-MIB::ciscoFlashMiscOpNotifyOnCompletion.101 = INTEGER: false(2)
CISCO-FLASH-MIB::ciscoFlashMiscOpTime.101 = Timeticks: (200) 0:00:02.00
CISCO-FLASH-MIB::ciscoFlashMiscOpEntryStatus.101 = INTEGER: active(1)
#destroy row
[dafrey@HammerHead TCL]$ snmpset -v 2c -c private 192.168.0.1 ciscoFlashMiscOpEntryStatus.101 i 6
CISCO-FLASH-MIB::ciscoFlashMiscOpEntryStatus.101 = INTEGER: destroy(6)
